It demonstrably is for many?Only 2 people. But it was just an example of how the government'a green policy isn't working and most aren't buying in to it. They won't until it's cheaper but it just isn't.
You need to do some maths.Sure after you spend 5 figures initially and wait years to break even lol
Or you could invest that cash and double it in that time...
The return on solar is like 12-15% a year and that is guaranteed. Now go find me an investment which is guaranteed with the same returns.
Are you dumb? Its saving you money you have to spend anyway.How is it 10-15% a year when you are going to have to wait about 8 years just to see your money back...
But you aren't really getting a return or profit until it's paid off.
If you put 10k in to a good stock 8 years ago you'd have made way more. If you put it in bitcoin you'd have well over 100k. Then you could have bought the stupid solar panels with pocket change.
Honestly, your answer to this is 'you could have put it in bitcoin?'The return on solar is like 12-15% a year and that is guaranteed. Now go find me an investment which is guaranteed with the same returns.
Then you wont have any problem citing just one investment which is guaranteed to return those numbers will you?You could have put it in a lot of things which are a much better investment
So the government will be turning the sun off someday soon as a tax grab?Nothing is guaranteed including solar. A bit like how the government changed their mind about EVs having 0 road tax
Even Nvidia has gone up 20% in a year and that's after Trump crashing the markets.
Indeed.Honestly, your answer to this is 'you could have put it in bitcoin?'
Good thing is even without export payments it is still a good investment, also the government have set a much lower level of guaranteed payment, the higher rate is really down to energy companies.They can change how much you are getting for any excess energy generate. They have in the past.
You are making short term savings, you aren't really making a return until it's fully paid off. Then you need to consider that the panels will degrade and generate less and less as they age.
Well those homes should have had heat pumps installed to start with. Now Octopus are not selling at a loss anymore the days of the £100 quote are over. For most people a heat pump is a lot more expensive than a direct gas boiler swap out.
Yes panels will degrade, again though I can tell you have not even looked into the rate of degradation. Hint - its not substantial enough to make any impact on the investment return.
8 years isn’t a long time and it’s 2 years less than average home ownership period.That's great if you plan on staying in the same house for a long time.
Irrelevant, I could run an old banger if I wanted to run an old banger. You can get old bangers in EV forms as well.Also how much are you losing per month on owning an EV... (lease, depreciation, etc). That alone is probably more than I'm paying to run my diesel commuter, plus my energy bill.
Ok then we’re close but you are coming out lower than us, for a family of…?
And which car doesn’t depreciate in value? Not that the depreciation matters to us.
This is a solar panel question though no? The EV question is for a different thread but I’d say it’s an added benefit.
I've already had solar fitters round, doing quotes etc and providing numbers. The initial costs weren't worth it.
They've changed their quote system recently to offer a 'turbo' (high flow temp) install and an 'eco' install and prices are higher. Going by comments on some Octopus heat pump groups new quotes are now higher across the board and the proper lower flow temp install is a lot more expensive than it was.I am talking about houses from the last 20-25 years. Not the last few years.
Have you got a source for this marked change in Octopus costs as I havent seen any evidence of a massive change.
Just the same impact from the houses that work and those that need significant work.
I never heard of a single £100 one, a few in the high hundreds but most were in the £1000-1750 range which is still cheaper than a gas boiler replacement.
