- 11 Oct 2005
- Doncaster
If it didn't revert back all you need to do is push the cmos button when the PC is turned off and it will revert it back to default settings.
That's a good point, I hadn't thought of that!If it didn't revert back all you need to do is push the cmos button when the PC is turned off and it will revert it back to default settings.
Which issues are you finding as "biggest" and "new"?The new BIOS doesnt fix the biggest problems and creates more. There is a beta, which fix them, im waiting to get official. Is for 5 days running already.
Ahhh yes.You can find the answers here, much easy for everybody:
Mine came with a white antenna. It doesn’t bother me much as it’s stuck under the desk.Quick question, what colour Wi-Fi antenna did you receive? I have a white one but was expecting a black one judging from the website.
First world problems, but it doesn't fit with my black case!
Yep, good thing it is magnetic - I've stuck mine on the rear of my case for now...Mine came with a white antenna. It doesn’t bother me much as it’s stuck under the desk.
The problem is the cable is FAR too short to be practical and the connector is proprietary so finding an extender has been a nightmare!Mine came with a white antenna. It doesn’t bother me much as it’s stuck under the desk.
worth going from the tomahawk 670e to the tomahawk 870e?
paired with a 5090 and 64gb of 6000 c30 or is it a waste of money
Anyone got this board up and running on any Linux distro yet? I have noticed a few haven't got the ethernet adapters working.
The main one i wanted was Debian that doesn't work! Unless there's a different kernel that I need to install which a few of the other ones I tried needed.Which distros?
Success.Thanks for confirming. Bit frustrating that they decided to ship these Wi-Fi antenna out in white. It wouldn't be an issue if I had ethernet where this build is going, but it's not an option.
I will contact MSI support to see if they have can swap the white for black. Will report back if I hear anything.
