- 19 Oct 2010
Ahh, yeah console is upto date, it was only network that was offering an upgrade. All sorted now though after going into the firewall and enabling the upgraded firewall options.
I've currently got a UDMP and a 16 port switch but due to the size of it all, I'm considering selling on and potentially getting some of the newer, smaller items to reduce the footprint. Would that be a backwards step and I'm being a bit daft?
I'm using 10" rack now and this currently sits on top of a 19u rack!
CGF has been fine for me, the one issue I had was self inflicted.
Anyone any further thoughts for going for a smaller setup?I've currently got a UDMP and a 16 port switch but due to the size of it all, I'm considering selling on and potentially getting some of the newer, smaller items to reduce the footprint. Would that be a backwards step and I'm being a bit daft?
I got mine from the EU store, didn't really concern me if I'm honest.
You get an option when you set it up as to which port to use for WAN. It'll try and auto detect but that usually fails if you don't use their designated copper WAN port /w a DHCP ISP. But it's simple enough to override.Well, ordered one. Decided that if I needed the 2.5GbE switch with the Max I may as well as get the Fibre and have an all-in-one box. Will configure one of the 2.5 ports to be the WAN and use the 10GbE ports for main PC and NAS. If something goes wrong, I am blaming you!
So if there's any setup tips for PPPoE and switching the default WAN port without issues I am all ears (first time UniFi user, moved over from ASUS).
Do you get done for CAT/Import duty or is the Euro price what you pay?I got mine from the EU store, didn't really concern me if I'm honest.
Thank youEuro price is what you pay. My UDR7 was from the EU store - I just had to get a UK C7 cable.
