Mines a sapphire nitro.
what case do you have, there is no way a nitro should be at 70% fan, mine was fixed via fan controller at 25% and the hotspot didn't pass the low 80's under heavy load
DarkBase Pro 901, with 10 fans running. The GPU/hotspot hits it's max in 5-10 minutes, so can pretty much rule out the case-ambient temp as an issue.what case do you have, there is no way a nitro should be at 70% fan, mine was fixed via fan controller at 25% and the hotspot didn't pass the low 80's under heavy load
I don't even think the 'feature set' that Nvidia typically had as a big selling point is as strong as it was before.Better feature set (not sure what that actually means) is meaningless when your drivers are so bad.
I think your right but why on earth would anyone need 10 fans never found I need more than two out and maybe one in if thatDarkBase Pro 901, with 10 fans running. The GPU/hotspot hits it's max in 5-10 minutes, so can pretty much rule out the case-ambient temp as an issue.
It's just a hotter chip, or bad paste job (maybe both). And it's fine after lowering the power limit. Custom fan curve also helps
Steel Nomad at stock : after 60 seconds Core:59/60 degrees. Hotspot 85/86. Fan% 43
More airflow, less (or less annoying) noise. I had the fans just sitting around.why on earth would anyone need 10 fans
certain it runs really well I do need to try it some time maybe with my next caseMore airflow, less (or less annoying) noise. I had the fans just sitting around.
3 are on a 420 aio, bottom rear and side intakes. Couple exhaust up top, they're all sat at 30/40% (except the aio), whatever keeps it quiet and cool.
to be fair techpowerup had it as the lowest dBA card they have tested and running at 57c on full loadThe review I saw of the cheapest 9070 XT Pulse model was quiet but was running very hot and had issues with fan ramping behavior. The cheapest 5070 Ti Phoenix has a 11.8% larger cooler than the 9070 XT Pulse and is more power efficient so I don't understand why this would be louder by a significant margin?
My Pulse doesn't even hit 60 degrees,it's the coolest and quietest card I have ever had unless I'm playing COD
Same for me. Considerably better in the games I play too. Made it an easy decision luckily.The reason I bought one is that it has better raster performance in the games I play compared to it's Nvidia counterpart.
If the 5070Ti was the card that had better raster in the games I played, I would have purchased that.
Sapphire Radeon RX 9070 XT Pulse Review
Sapphire’s Radeon RX 9070 XT Pulse trades flashy extras for substance, to hit its $600 MSRP. There's no RGB lighting or factory overclock, but you get an outstanding cooler that runs whisper-quiet at full load with good temperatures. Performance where it counts.www.techpowerup.com
same as me then the extra features people talk about with nvidia never apply to me or anyone I know in real lifeYes. I was originally going to get a 5080 but at its price point it was hard to justify the 16gb. When the 9070 XT launched and I saw it's performance in the games I play, it was a no brainer.
There will be users that this doesn't apply to, for example people playing PT games or gamers that do productivity workloads, however that's not me.
I can't play cod on my it's just crashing all the time with DirectX errors and drivers crashes.My Pulse doesn't even hit 60 degrees,it's the coolest and quietest card I have ever had unless I'm playing COD
is that still going on it must be a software problem not amd as suchI can't play cod on my it's just crashing all the time with DirectX errors and drivers crashes.
Same.It started a few weeks ago I think with a update,now I can't even get through one game since the update yesterdayI can't play cod on my it's just crashing all the time with DirectX errors and drivers crashes.
It's definitely a COD problem as it was perfect up until the update before lastis that still going on it must be a software problem not amd as such
did you fresh instal windows yet >? I would be tempted to try a spare drive with just windows and a fresh cod instal
