Gigabyte B650 Gaming X (AX) Owners
FB4
12.64 MB
Mar 17, 2025
  1. Checksum : BAEF
  2. Update AMD AGESA 1.2.0.3a PatchA. Please also update AMD Chipset Driver to 7.01.08.129 or later version to improve gaming performance for 2CCD Ryzen 7000 CPUs
  3. Optimized memory compatibility
  4. Enhanced PCIe compatibility
  5. Fix AMD CPU microcode signature verification vulnerability (CVE-2024-36347)
FB4
12.64 MB
Mar 17, 2025
  1. Checksum : BAEF
Hey Deekin, thanks a lot for your info and courage. I also got 9800X3D for my B650 Gaming X AX rev1.3 BIOS FB4 and it works just fine.It even offers new Curve Optimizer. Now only time will tell if this combo is safe to run. I mostly just game.
Also, with Gigabyte's versioning FB5a means it's an Alpha BIOS or do Gigabyte just use hexadecimal numbering for their BIOS versions or something?
Anything with a letter after the number is a beta or alpha release. Normally starts at a then increases for further revisions.
F32a, F32b with the final release being F32 as an example.
Good to know, thanks. I think I'm on F33f (B650 Gaming X AX V2) so that sounds like a beta BIOS and maybe I should switch to the F33.
I will also avoid F34a and wait for F34.
FB6
12.70 MB
Jul 21, 2025
  1. Checksum : B3BE
  2. Update AMD AGESA 1.2.0.3e PatchA for new CPU support
  3. Fix TPM2.0’s out-of-bounds read vulnerability (CVE-2025-2884)
  4. Enhance memory compatibility
FB7
12.70 MB
Jul 31, 2025
  1. Checksum : C7A7
I wonder what was changed, the notes are identifcal as FB6 that it replaced.
For version 1.0-1.2 -
F36
12.70 MB
Jul 31, 2025
  1. Checksum : E6AD
Tho if pci-e 5 support is important do note this article for agesa 1.2.0.3e bios updates.
F36
12.70 MB
Jul 31, 2025
  1. Checksum : E6AD
Typical GB, lying to us that our motherboards won't work with 9000 series cpus but actually works fine, now this...
I plan on using a PCIe riser (4.0 or 5.0) cable for a Lian Li Upright GPU bracket mount. I want buy a Lian Li 600mm PCIe 4.0 riser cable but I heard other users with our motherboard encountering problems when using one (ie. intermittent black screens, running at PCIE 1X). Anyone tried using a riser cable with our Gigabyte B650 Gaming X AX and what are your experiences? Please list the riser cable used and your GPU, thanks!
