Man of Honour
- 16 Jul 2009
- Edinburgh
I personally can't get over how uncomfortable this device is. I get that it is better than s1, but this does not change the fact that it is still nasty to me (in comparison to steam deck, any gamepads etc). I play on tv only with cyclone 2, as all I have while playing handheld is unpleasant feeling.
I don't find it that comfy either but have a Killswitch on the way; I have to admit though I've actually been using it propped up on it stand and just using the Pro Controller when I'm having a quick blast rather than hold it!
In my shopping basket I have a 13" 4k OLED portable monitor that can be powered by a battery or directly off a USB-C port like a Mac...I have been thinking getting one as my travel work set up so I can use dual monitor with my MBP....anyway, normally I wouldn't get the touch screen version but I am now thinking i should get the touchscreen version because I can then use it with the Switch / Steam Deck. The problem however is the Switch wouldn't work without the official dock I think whereas the Steam Deck can output via USB-C to HDMI via a regular cheap USB hub.
I've got a similar screen here, I'll give it a go later and see if it does anything.
Looking forward to some reviews here of killswitch grips or genki?
Killswitch coming next week delivery times depending!
Is the expansion pass worth it for switch online?
I know it comes with the two zelda updates for switch 2 but I'm not sure if it's worth it elsewise
Easily worth it; I've played loads of the N64 and SNES stuff and now with Gamecube too
