OK so another idea I had. If you look back at the original mobile Stroker 12....
It had a rather nice big plate on the back. With stickers on. So, using modern techniques I want to make something similar. Annoyingly they did not have 5mm in the same gold, so I got an A3 sheet of that.
I mean in gold. Obviously sold out. I also got a A3 sized sheet in black.
Again in 3mm. Which will total 6mm or over (due to sheets never being exactly 3mm). This will be cut with a centre hole the size of the magnet plug OD, and then be the size of the magnet OD. Which I don't have access to as I am at home now. I will do that and machine them when I return.
