RealOEM is for BMW's, Mini theoretically isn't a BMW, although technically it is...meh still doesn't list part 51217404345 as being needed on an F60 Countryman![]()
What car? Model and YearService records that are held on the iDrive
Anyone know how long after the due date it can be done and sill show the green OK symbol?
Web searches don't seem conclusive
Neither is a Rolls Royce but I can get part numbers if I ever need to replace the Starlight Headliner on my CullinanRealOEM is for BMW's, Mini theoretically isn't a BMW, although technically it is...![]()
2017/18 640dWhat car? Model and Year
The technician can choose, I believe they've some guidelines, there's also a DIY method to correct it to 'on-time'.2017/18 640d
thanksThe technician can choose, I believe they've some guidelines, there's also a DIY method to correct it to 'on-time'.![]()
I got one of these.How did you get AA on your M140? Guessing some sort of aftermarket solution?
droiduk.com
Ah I see, so perhaps the connected drive stuff will keep stay working. If its only things like weather, traffic, news etc. its really not worth 120 of my hard earned
Yes, once they need replacing - I didn't bother switching over until the tread was low enough when I had my M140i.Do people usually ditch run flats for regular tyres?
I've got Bridgestone potenza S001 on the car at the moment and it's so crashy and harsh at low speeds. I know the M140s were always a bit bouncy in stock form but I'm wondering how much of this is tyres?
This is my first experience of run flats, they've got about 4mm of tread so good for a while but I am tempted to swap them out for a bit more comfort at lower speeds.
Do you know what version of the MMI box Droid UK sell? Do they provide links to software upgrades for them? From my understanding they can connect via the cars Bluetooth these days and not AUX and it stops the hissing, is that correct?I got one of these.
BMW Wireless Apple Carplay / Android Auto - MMI Box - Droid UK
Install BMW MMI box for wireless Android Auto and CarPlay integration. Verified hardware, seamless connection, and trusted UK aftercare support included.droiduk.com
Install only took about 20 mins and it's been faultless. Hold down the HOME button on the iDrive controller for 2 seconds and you can switch between iDrive and AA. I have mine set up to run the MMI box when I start the car and you'd never know it was there, no boot up time etc, it just works
Yeah probably not worth it, I wasn't going to bother with an MMI at the time so I paid to upgrade the maps as I went down a road built about 2 years ago that it didn't even recognise![]()
No idea but I asked if they do softwares updates for them before buying and they said they do issue them when needed.Do you know what version of the MMI box Droid UK sell? Do they provide links to software upgrades for them? From my understanding they can connect via the cars Bluetooth these days and not AUX and it stops the hissing, is that correct?
How do you know if you have run flats?Do people usually ditch run flats for regular tyres?
Usually says on the tyre wallHow do you know if you have run flats?
Whole range of markings depending on the tyre manufacturer, but normally some variation of RFT, ZP or ROFHow do you know if you have run flats?
Are they that unreliable/expensive?For a car like that, which can throw up large bills when things go wrong I would always renew a warranty but thats me.
