Samsung Odyssey Neo G9 (G95NC) 57" Uber-Wide
Hmm, in anticipation of this, can anyone recommend a good calibration setup?
Was also looking at a Silkland 2.1 certified 2m cable - appreciate I haven't got the graphics card yet, but it says certified for dp 2.1 up to 240hz so should suffice?
Also... any good ultrawide background resources? I use wallpaper engine on steam and have a few on rotation but since I've got 2 monitors atm they're not great for UW.
do you mean calibration setup as in your want a device to calibrate your monitors colour with? If yes then that is very expensive for a high quality device and only useful if you are professional calibrator, I am sure you can call a professional calibrator in but will set you back anywhere from £300-£500 and would only recommend this if you need accurate colours from the monitor. If you works is such that you don't need that then its not worth the price or hassle.
The colours out the box are accurate enough for 99% of people also if your works is such that accurate monitor has a impact on it then this monitor is not really what you want and I would recommend you look at more professionally oriented screens.
No I literally just meant settings I can tinker with to try and get best image quality out of it, if its good out of the box that will be fine for me.
Its fine out the box unless you notice something very off, just use this website to run few tests and see if anything is way off.
if you still want more colour calibration but don't want to spend thousands then you could buy a cheaper calibrator in the £300-£500 range but I don't have extensive experience with them to recommend. I know they are not as accurate as professional stuff, maybe someone else can recommend one.
Just asked if I can get one for work!
Currently rocking a Dell 3417W I've had for a long time now, but moving to a new building/office and I fancy an 'upgrade'.
Fingers crossed, the issue is being a bit extravagant, it might be a step too far, even the 3417W was seen as out there back in 2018, however, I've been allowing everyone to have 3 x 27" 1920 x 1080/1200 monitors and the 57" to me is just combining 3 monitors in one..
Posting in the wrong thread… doh!
Well she turned up ten days ahead of the original schedule, and all I can say so far is I'm impressed. I haven't done work yet, just been installing it this evening, excuse the wires - work in progress whilst I get it adjusted:
So far for work certainly I am not disappointed. Not played anything other than AoE2 on it yet so not much to go on gaming wise but we’ll see!
Right after using this for a couple of weeks now I thought I'd add my... thoughts on the monitor.
This is a wonderful monitor for productivity purposes, not so much for gaming, but I'll come on to that shortly.
When I use the word screen, I mean a vertical window, resized to fit across - until now two monitors that I've always had. I like to work across 3 or 4 "screens" usually, a couple of coding windows, when doing code reviews and such I need a minimum of 3 screens, with a calendar floating around somewhere visible so that I can keep track of meetings as I'm often in meetings that need a proper bit of preparation. The text clarity is brilliant, I use vscode mostly these days and I have not noticed any issues at all, out of the box to be honest, I haven't had to calibrate anything. I am involved in a lot more architecture meetings these days working with lots of process diagrams and this really helps me see more.
I also work in the azure portal a lot and since that ui was designed by satan himself and adds scrolling panels sideways I'm just able to see more in one go.
As for gaming, well this screen is just too big - thats not a fault of the screen persay, simply a case that my graphics card can't run it properly. That is ok, I knew my card wouldn't be able to push this properly, and until 5090 prices aren't with the fairies and the cards rarer than unicorns I won't be getting one anyway. Heck probably have to wait for a 6 series (assuming nvidia sort pricing and supply) or UDNA4 card to actually be able to run anything fullscreen - that said its also actually just a little large for some games I play - RTS games I'm find I can't see the entire map and minimap in one easy view, so when playing something like AOE2, I actually enable PIP and cut the screen down to two thirds which works perfectly. Not something everyone would want to do I understand but it works for me, and this is predominantly a work monitor, I love it. In some mythical future where my wife lets me buy another monitor as well as this one ("that ones massive why do you need another??") I could see me getting a smaller/oled screen purely for gaming, but I'd need to solve the desk/space issue as well because with this screen I can't comfortably fit another monitor anywhere (in my house :p).
The on screen display is a bit naff, and a pain to use if I'm being honest. Due to the size of the screen, its sat as far back as I can put it on my desk, so I have to reach quite far to do anything on the menu, which is a necessity with the PIP mode which I use all the time. Not having a remote for a screen like this, and at this premium price tag, is frankly, terrible. It also doesn't have a true, or easy to use, kvm. You can do something that I haven't bothered to investigate because I just use Mouse without Borders (brilliant multiple computer software if you need one) and it works just fine for how I run my setup (dev desktop and laptop). No USB-C power hub, which again, on a screen this expensive I feel should be included. Yes I knew this before purchasing and its not a problem, its a nice to have - rather than having a thunderbolt dock under my desk I'd much rather just run a single cable from my laptop to the screen. Thats partly aesthetics, its partly wanting to not spend a few hundred on an expensive dock, its partly expecting that sort of functionality from a premium priced product. Maybe the next iteration will have these things, but then I'd dread the cost!
tl;dr
Great text clarity and picture quality ootb
+ Amount of screen real estate
+ Productivity wise as a developer and soon to be software architect this screen can't be beaten
+ The PIP mode is really good, I haven't been disappointed or found any issues using a laptop on the hdmi and desktop on the display port connections.
- The OSD is pants, and using it is a pain.
- Too big for gaming, or not great for the few games I play
- Needs a unicorn graphics card for gaming
- No remote
- Only a single DP
- No USB-C pd.
- Cost
- You need a big, strong desk
Do I regret this purchase? Not at all. I genuinely feel like this has been a fantastic purchase. It has some downsides, which at this sort of cost some will consider simply not worth the compromise which I get, but for my main purpose, this has been a game changer.
the most important thing for me too was using it with visual studio code and visual studio and honestly would have bought this monitor just for this purpose alone, as it makes life so simple with just one giant screen. I glad you like it, just waiting for Samsung to do an OLED version and little bigger if possible, I still would like little more vertical height, nothing much, maybe just 2-3 inches. I think this will eventually happen but might not be a few years off but warranty needs to be 5 years if I am going to buy an OLED monitor, cant have a £2500+ monitor with risk burning in after 2 years. There is now new backlight technology that is being developed for large TV this year that might eventually make it to LCD, with RGB backlighting that makes things even better but not oled like. Interesting few years that's for sure.
also wanted to say with RTS stuff look online for the game you are using and see if there are any mods in the nexus mode manager, I have used some mods for sekiro and god of war to make them wide screen compatible and unlock 60hz, also with elden rignt too.
In the future I might add second screen to the top as I find myself needing even more screen space but I will hold off for a while longer yet.
tl;dr
- No remote
- Only a single DP
- No USB-C pd.
- Cost
I've had the 57" since it launched and this pretty much sums up my impression of it. Its far better than the Neo 49" which I also had.
My only gripe is that it messes up some program resolutions and moves things about on screen when I turn it off/on, or switch inputs and that is causing me major pain at times when i have a ton of stuff open but I hear that's more of a Windows issue.
It has been ongoing for ages though and can't help feel the huge resolution affects things worse more than more standard resolutions.
I'm even tempted by a couple of 5k monitors (as I sometimes use Mac too) to see if it fixes the resolution/layout issue but right now, 27" might be to small but hear there is an Asus 32" 6k out soon which I've got my eye on as all my usage is productivity with zero gaming.
The text sharpness on the 57" is very good but going from its 140ppi to 218ppi on a 5k/6k will be even better.
I'm still on the lookout for a 'perfect' monitor but I don't think I'll ever find it and have been through loads :)
Anyone got this mounted on an adjustable desk? Looking for a new desk so I can mount the base to the left side of the desk so I can have the monitor as far back as possible on a 60cm depth (the ones I am looking at) instead of the arm folded on itself.
This is a a great monitor but make sure you get a decent HDMI cable ( otherwise you get flickering and artifacts ) and if you are using Display Port DP 2.1 then get a proper certified cable otherwise you get flickering and artifacts. I returned the first rated 2.1 DP cable to Amazon and got another one and its superb on a RTX 5090 ! Full Res at 240Hz !
I've been on a rollercoaster of monitors last few months, initially parting ways with my 49" Samsung OLED G9 due to poor PBP performance and lack of vertical height. I then went back to normal aspect ratio for a bit but was missing the ultrawide experience so ended up being patient and got my hands on the LG 5K2K. Great monitor but the 800R curve was just too much for me as 80% of my usage will be for productivity.
I took delivery of the 57" G9 about a week ago and couldn't be happier with it (for now). I was looking at monitor arms but ended up just using a flat TV wall bracket and mounted it onto there which works perfectly for me. The 1000R is also just perfect, I can sit centre and covers most of my peripheral vision. I was a bit worried that going away from OLED would annoy me but after playing around with the settings on this monitor I don't really miss it at all.
PBP on this is a godsend. I can run 32" @ 4K side by side from the same source with ease. Very handy for use with my work laptop which would otherwise struggle at full native res. Even scaling down to 2560*1440 is not a problem. Main PC is connected via DP 2.1 and I can drive the full res @ 240hz with a 5070Ti with no issues on desktop. Not tried any games yet but will give it a spin this weekend.
The text clarity on this monitor is superb too, I'm sat about 70cm away but everything is super clear and sharp.
Looks like I have found my end game monitor.
If I had to find any cons I'd say the monitor can get a bit warm but nothing worth concern.
Just playing around with PowerToys and FancyZones which on initial thoughts seems much more better than the bog standard windows snapping options.
If anyone has any other cool tips/tricks for productivity would be interested to hear.
its hands down one of the best monitors out there now, also the best LCD monitor there is so far anyway. really hoping for an oled version with a little bigger size, so that we get more vertical height, Its improvement over 49" version but needs maybe 2 more inched in height and plus whatever corresponding length increase that entails. I still prefer lcd for productivity work. Enjoy the new monitor:)
This is the problem I have - I really want an OLED version of this. ITs such an amazing monitor for any productivity but I really miss the OLED for games but when I go on OLED I then miss the productivity aspect !
Probably never to be fair - Expensive and Niche
is not 57" g9 already in this category? only good thing is this niche product actually perform very well and actually worth its price unlike many other niche products. There will always be niche products, only difference with this specific one is that if they make an OLED version, I can see MANY gamers if not ALL jumping boat to this size or similar. Going forward, I see LCD loosing even more market share to OLED monitors as the years go by, specially with the advent of printable OLED screen for monitors and in particular gaming monitors.
the future is OLED, unless QDEL technology matures to reach consumers in the next 10 years. Apparently not much needs to be changed with the manufacturing process of LCD screen to convert the line to QDEL, so anything can happen I suppose.
Loving my 57 which I've only had for a couple of days, have had the original G9 49 since it first came out and this now sits above the 57.
The 57's display is much better, colours are clearer and darks darker.
Main use is games so my new 5090 comes in very handy.
Playing Kingdom come Deliverance and Alan Wake 2 currently, both are cinematic in the extreme.
