Samsung Odyssey Neo G9 (G95NC) 57" Uber-Wide
I keep swinging between one of these and the dell 5k2k 40”.
My use case is 75% work - programming - so I don’t want a Uber oled, but really want massive screen state, and my concern with the dell is I’d still want another monitor - despite all the pixels..
I am well aware my current gfx card (4070 ti super) won’t drive either to their full potential for gaming but text clarity is the number one issue for me, how does this one stack up? I don’t really know much about Samsung qled, and of course all the marketing claims amazing text clarity…
I am well aware my current gfx card won’t drive either to their full potential for gaming but text clarity is the number one issue for me, how does this one stack up? I don’t really know much about Samsung qled, and of course all the marketing claims amazing text clarity…
sorry for the wall of text
I also bought it mainly for programming and gaming was really an after thought. I will tell you how I am using mine, right now I have the screen partitioned into 4 sections, one if for my pdf, visual studio code, windows power shell, and internet explorer. I feel like any more windows and the text will be too small to read comfortably, a fifth window would make the text more difficult to read and get eye strain. Text quality is sharp and I love it, its a joy for programming and I love it and cold not see myself going back to normal monitor ever again.
You could if you really wanted more space is to buy a 55" Samsung 8k LCD TV, it has drawbacks but purely for real estate space you cant beat that and I was contemplating it at one point but it was just too much screen to sit at close distance. I was also considering that Samsung odyssey Ark and my brother has one but decided it was too much screen and the resolution was too low for me.
I know someone who has two G9 49" ultra wide oled stacked on top of each other and another person who has two of the 57" g9 stacked on top of each other and I may go this route later if I need more space which I do.
There is also LG new 45" ultrawide 21:9 5k that just released and that is quite good but I would rather Samsung 57" to be honest, I need more width than height and the height of the 57" is equivalent to a 32" monitor so that was enough for me, I mean if it was little taller and wider would have been excellent but maybe next revision.
If you buy oled and the pixel pitch is not high enough then it can make text reading very straining because of the pixel layout, this is what happened to me when I tried a 65" oled screen as a monitor, it was to much and was tempted to try 55 and 48" but glad I went with 57 LCD for work, I don't have to worry about burn in and the razor sharp text is so comfortable to read. For about six months I did lots of measurements and saw lots of monitors and TV and finally settled on the 57 and was very happy with it, actually every time I turn it on I still go wow it looks amazing.
gaming is also very good experience, maybe not oled quality but this is not some cheap looking LCD from 10 years ago. The colour are good vibrant and HDR is excellent and gets quite bright. You will unfortunately need something like 4090 or 5090 or 4080, 7900xtx at minimum. I am currently using a 6950xtx as it struggles on new titles but old ones are fine. But I will say ultrawide gaming is such an amazing experience, recently bought "No Rest For The Wicked" and it looks amazing also assassins creed mirage looks fantastic, so does Doom Eternal. It may not be Oled but its still excellent experience. You will also need HDMI 2.1 port on the GPU that only currently AMD 6000 and 7000 series has and the Nvidia 5000 series has, that's if you want 240hz at full resolution.
Hopefully Samsung makes a slightly larger and Oled for next revision but would also be happy with slightly larger and LCD. I think if its going to be bigger and wider then Samsung will use OLED because it has much wider viewing angles compares to LCD, it would allow it to be wider and not go blurry at the edges of the screen just hope they keep the same curve.
@AMDPower dont apologise that was an extremely helpful post that I think is going to end up costing me 1500£ :p.
The four windows alongside each other is basically how I want operate now albeit I can’t really because with a 38” and 27” it’s just nowhere near enough.
I often run two vscode window side by side, chat windows, documentation etc and four “proper windows” is really what I want to achieve. As with any monitor I’m concerned about text clarity but sounds like you’re very happy with it.
My card definitely won’t drive it for gaming but that’s life and if it helps achieve what I need work wise I think it’ll be worth it, and I’ll consider a 5090’in two years when there’s stock available :p.
Sounds like your use case is pretty similar to mine. After having this a year I'd really recommend it. There were lots of horror stories on release but I've not had 1 single issue.
I work in data so spend a lot of my day with walls of code and tables. It is perfect for that. When working in other offices at times I have to dock into smaller multi monitor setups and those are significantly worse.
Text clarity is the best I've ever seen. The PPI is so high it's really crisp.
A couple of things to be aware of. If you do a lot of screen sharing in calls it's more fiddly as you have to share windows and not the screen as it melts other people's resolutions. Also if you're connecting work laptops make sure they have a good enough Thunderbolt socket on them. Using this screen at anything less than the recommended resolution has to be avoided. So if you need to use specific old devices with it then it could be worth avoiding.
I've rarely gamed on it as I've also got a 55" OLED connected to my PC for gaming. With DLSS some modern games are playable on a 4090. The HDR isn't great compared to OLED in my opinion & looks washed out in Windows, although I think that's a Windows problem. I also find the fish eye effect in some games off putting, Cyberpunk feels odd to me.
Oh and make sure you have a big enough desk!
@jimdriver thats perfect thank you. I do a lot of database programming as well so usually have various windows in the background that I’d like alongside, the clarity sounds like what I’m after - thank you for your input as well.
I’ve got a third party Lenovo thunderbolt dock which is pretty powerful so I think that would be ok.
I think the only other question might be my desk size. It’s 58” wide, and whilst I know the monitor is 58 diagonally, it’s what, 54” physically wide? Might it legit be too big for my current desk?
I just measured mine for you and its appx 52" wide from edge to edge. You definitely at some point want to get this onto a monitor arm that supports it. The stand it sits on for me does not go high enough and secondly it takes up a lot of space because the legs are really long. I also agree with Jim text clarity is excellent and you will love it. When you get it update the thread on your experience with it.
you will be surprised how many titles you can play even with your 4070ti with some adjustments of course, my 6950xt is roughly similar to your 4070ti in performance. You can always upgrade later on if need be, hopefully the 5090 stock situation will rectify in few months.
Think that’s made my mind up, thanks!
I'm looking at a few options, I've stopped short of ordering the humanscale mount with dock at well over 1K£ :cry:...
What mounts are people using? I believe the (new) Ergotron with HD Pivot (https://www.ergotron.com/en-gb/products/product-details/45-693#?color=white, don't think its a competitor, if so I apologise and will removes) is supposed to work now, but obviously wanting to compare options and see peoples experiences. I've a two inch solid oak desk so should be capable of arm mounting. And I can't find the ergotron in stock anywhere (in the uk at least).
Also can people recommend cables to use? Admittedly not got a DP 2.1 gfx card, yet, but will look into that in the not too distant future..
I can confirm there is a Bewiser heavy duty arm but I had to get a replacement vesa head as the original one failed, check out ULTRARM Heavy duty on the river website that also works with the 57"
Anyone using a DP cable that's DP80 And longer than 2 meters, it's now February and I can't see anything available
Oh, nice. They're clearly marketing it for the G9 even if they can't explicitly say it :p.
Do you happen to know... does the 57" need any adapter for it?
Another thought - I currently have a BenQ Halo screenbar, but by all accounts this does not fit the neo g9, the screenbar pro apparently does but can anyone confirm? Does anyone else use a screenbar?
I'm not entirely sure how I'll cope with a white monitor but lezzgoooooo! Am excited now, and ETA is 26th :(.
Also sad about no USB-C pwd, but I guess with my thunderbolt hub it will suffice as I have that mounted underneath my desk (my current setup doesn't have pwd) so whilst I'm not gaining anything, I'm not losing anything. I just mount my dock and laptop hidden away.
Got this beast on the recommendation of this thread, its the ultraarm:
Man it is heavy. Gives me some confidence at least that it can support the monitor. Now I just need the actual monitor to turn up!
Hmm, in anticipation of this, can anyone recommend a good calibration setup?
Was also looking at a Silkland 2.1 certified 2m cable - appreciate I haven't got the graphics card yet, but it says certified for dp 2.1 up to 240hz so should suffice?
Also... any good ultrawide background resources? I use wallpaper engine on steam and have a few on rotation but since I've got 2 monitors atm they're not great for UW.
