Got mine today, working great in testing with my Mac Mini M2. Just need to sort out the Ultrarm on the desk to get it mounted, always hated the stick out stands.
welcome to the club, most people don't know what they are missing out on. After you play widescreen is hard to go back to normal 16:9![]()
Well I am upgrading from the OG 49 G9 so been in the game just not the 57 gameMoar res ftw!
What settings are you running at?
Is it possible to run a 4k firestick through the HDMI input on one half of the monitor and then use the other half to play games at 4k/240hz (via display port) at the same time or are there some limitations on refresh rate/resolution when using two inputs side by side ?
I've got a 180x80cm that fits it comfortably with a 27" vertical screen I also need. I can it can be fine though on a 150cm wide deskHi all,
What size desk are people using? Looking to get the Cooler Master 57" monitor and I have a W-155cm x D-75cm desk.
Anyone using the VESA mount, what mount are you using?
Pictures welcome!
Thanks!
That's my plan hoping the pricr/stock is OK on launchAnyone with one getting a 5090?
Considering getting one again, after all the good news about MFGthis is the monitor that gives me the best chance of upscaling content to crazy resolutions and with MFG factored in, could be fun.
If its the philips 49m2c8900 or cheaper variation I returned mine was not that impressed to be honest,Glad I'm not the only crazy person here
I have a code I have to use by 25th if I want the G95NC.
Hard decision to make with a £750 Philips 240Hz 4K OLED available.
I've just ordered an lg C4 48" 4k oled and will get that hooked up to the 5090 as another option although I might struggle for space lolSorry for confusion Philips is a 4K monitor I'm considering if I don't get the G95NC
I've got this oneSupporting my Neo G9 was a key reason why I was thinking of updating to the 5090 as of course the 4090 doesn't have DP2.1
The 5090 price and small-ish performance bump have put me off and it seems like it won't be until the 6090 I can take advantage of the 240hz speed.
One thing I wasn't sure about that I wondered others might be is the DP cable length. I know there's a newer DP2.1 standard that allows longer cables but does anyone know for sure if those cables will work with the G9?
I think I need at least a 2m cable, possibly a 3m so it's not really tight / I have to make a hole in the desk to make it reach.
Ah great. It achieves 240hz with a DP2.1 card? Amazon listing of course doesn't mention this monitor but does only say 120hz for 8K (which I know this monitor isn't really)I've got this one
KabelDirekt – DisplayPort 2.1/DP 2.1 Cable – 5m
