No, no sensible reason that I can think of unless the shock was replaced after the 2022 test and they started buggering about before the 2024 test. Seems very unlikely though I'd say.
Roughly how much are DCC shocks to replace?
That is roughly what I had on mine by the time I sold it, made 270bhp and 310lbft boost was brought in less spikey low down . A lot of maps at the time went with a massive boost spike to make it feel faster but would tail off quickly. Ran Goodyear F1s on it and it put down the power well. Only engine issue was a thermostat around 80k, common issue and stuck open rather than closed so not a huge problem.I'm (finally) off to r-tech performance on Wednesday to get my Mk5 Golf GTI remapped alongside injector refurb and intake walnut blasting.
Car has Stage2+ hardware (Direnza Intake, GFB Diverter valve, S3 Alloy intercooler, 3" downpipe with 200 cell sports cat, VIS HPFP, VIS Balance Shaft Delete, R8 Red Coil Packs, NGK Iridium Plugs...) and is on Esso Super Unleaded Fuel.
Mechanically all spot on with the timing chain and tensioner replaced, as well as the cambelt... PCV system all updated... its ready for this.
My hope, is 270-280 BHP and 320-330 Lb/Ft torque as its still got a K03 turbo..... However I probably have a weak actuator as its got 186,000 miles !
I'm also playing around with Youtube a bit - primarily for my Cayman - but I've done this video on the Golf, and will do a reaction video after the tune ... will report back on Wednesday evening !
Second track day at Anglesey last week, such a good track and we had the best weather, great mix of cars and guys, and some really good laps! Had to fill up mid way through the day!
I proactively changed the blow off valve a couple of times and the PCV system. I had it from new and sold it at 127k ish it was a great car but had rust coming in it had been through a few heavy Scottish winters 2010-2014 ish which took it's toll on it even cleaning it regularly. If I'd kept it for longer I'd have fitted the k04 turbo.
That mk 8 is beautiful!My last 3 VW's, the pinnacle OF COURSE being the Polo!!
Now to get some string back gloves and a heated slipper.
