- 23 Jun 2004
- Blackburn
is it for portal though ? thats the key question.
Yeah portal only
Its going to be within portal no matter what, but the fact that he says "you can join an existing server or create your own" sounds pretty similar to a non-portal server browser
I don't have time to look for the post right now but the server browser they are implementing isn't really a browser like the old days, you can only find servers that are running. Sound great? Kinda...problem is matchmaking is just cost saving exercise for EA. Servers spin up and then when the round is over close and you get sent to another. In the good old days your favourite community server would be running 24/7, server empty? No problem, just join and with a bit of luck it will start to fill up. Doesn't sound like you'll be able to find that awesome server you played on last night with the new server browser unless someone keeps making it.
Only I'm way off the mark but that's what the post made it sound like. I'll try and find it later when I get time.
