- 20 Jun 2016
tnx mate. I didnt know about the ATX 3.0 and 3.1 change tbh first I heard of it.The GPU connector is the main difference. It had a slight redesign and the 3.1 spec - so it's safer than the one from 3.0 although the safety feature's mostly from the cable itself I believe, so might be possible to get same benefit from using a newer cable for the older 3.0 spec - but if you don't want the hassle of finding out the hard way it isn't, the 3.1 is guaranteed to be safer vs potential unknowns with the 3.0. This PSU also has 2x those GPU cables and ports, I am unsure if that is part of ATX 3.1 spec or just this PSU, but that's something here on this PSU; 3.1 also has a higher hold up time on the voltages it gives out vs 3.0, although other than spikes of outtages, I'm not sure what that's useful for.
This is what I dug up on the CORSAIR site.
ATX 3.0 vs ATX 3.1: What's the Difference?
Covering the differences between ATX 3.0 and ATX 3.1 for PSUs.
pretty much what you said.
Connections are shortened PSU side I guess ( and VGA side ), to make it safer?
Cables are unchanged.
Hold up time is 12ms compared to 17ms? Which results in better PSU efficiency>
