Is there a motoring equivalent of hypochondria?
I was going to suggest a bicycle, but those are electric these days aren't they?My god, talk about trying to convince yourself of something, I suggest you get rid of the BMW and get something like a Mk1 Escort or original mini which doesn't have all the electrics etc. to go wrong
the £1M question is...is it really going wrong though?doesn't have all the electrics etc. to go wrong
Just replace the car mate, it's clearly trash and not fit for purpose
The car is great and I love it. Let's leave it there
Not sure what the others were like if this is what you deem the best, surely with all these 'issues' it must worry you to drive it?Nope I have owned 3 beemas now . And this is the best
SUVs can get in the bin, but there's not really much choice these days is there? PHEV & EV Estates these days have zero luggage space due to sloping rear hatches for efficiency and batteries in the bootThis will be a big seller if they can get the deals right, decent range and everyone seems to love SUV's.
Yes, it's called owning an old french carIs there a motoring equivalent of hypochondria?
I suggest you focus on your mortgage. That sounds like it's about to implode.The car is great and I love it. Let's leave it there
have to accept that the neither the weight nor centre of mavity height is much higher than any ev estates, and you will gain some rear legroom too,SUVs can get in the bin, but there's not really much choice these days is there? PHEV & EV Estates these days have zero luggage space due to sloping rear hatches for efficiency and batteries in the boot![]()
You almost certainly had it on your 120d as well, it appeared around 2008.
tbh a lot of these testers just throw up standard faults that may or may not be there. i had snap on/bosch/and launch to name a few and often got different faults on same vehicle , if it drives ok and doesnt flag a warning light as others have said just drive it . it will soon tell you if it needs attention....bit like the wifethe £1M question is...is it really going wrong though?
