BMW and M Power Owners
My god, talk about trying to convince yourself of something, I suggest you get rid of the BMW and get something like a Mk1 Escort or original mini which doesn't have all the electrics etc. to go wrong
I was going to suggest a bicycle, but those are electric these days aren't they? :p
Will set itself on fire if not sorted pronto, not as if they’re obvious enough to flag up in the display so it must be ready to self implode.
Nope I have owned 3 beemas now . And this is the best
I think it looks a bit better in the videos, and the grille sort of works as part of the wider front-end with the lights.
This will be a big seller if they can get the deals right, decent range and everyone seems to love SUV's.
SUVs can get in the bin, but there's not really much choice these days is there? PHEV & EV Estates these days have zero luggage space due to sloping rear hatches for efficiency and batteries in the boot :mad:
have to accept that the neither the weight nor centre of mavity height is much higher than any ev estates, and you will gain some rear legroom too,
they don't need a baking panoramic roof either, for a few mm more of headroom (eco model 3 w/o glass roof will be interesting itr)
id7 seems a reasonable compromise, and ix3 lower than predecessor which bodes well, maybe 3 series replacement will surprise with lower height battery pack they are using.
e: in a bad bonnet world you just have to outrun the opposition
the £1M question is...is it really going wrong though?
tbh a lot of these testers just throw up standard faults that may or may not be there. i had snap on/bosch/and launch to name a few and often got different faults on same vehicle , if it drives ok and doesnt flag a warning light as others have said just drive it . it will soon tell you if it needs attention....bit like the wife:)
