- 18 Oct 2002
- Kuala Lumpur, Malaysia
I've done it for a few years -having a tough alloy 'commuter' wheelset, then a 'summer fun' carbon aero one. But think I've reached the point now where going for 2 bikes there's very little need. I still might revamp some of my alloy wheels for some CX use and the fact I've got 3 sets, seems silly not to have a 'super bad weather' commuter set which would also do dry CX, so more of a gravel tyre on them alongside the real mud grippy ones...
Fairly straight forward. I've swapped them around, even cut some ends off and refitted barbs+olives when changing bars over so just cut them and fit new bits - must be as easy when fitting new hose... I've the Shimano kit and long overdue changing one of my hoses on my commuter, it's a 'job to do' when I get around to it... Need to change the groupset (11s di2 franken self-build to 12s Shimano 105 di2) but also changing the front brake from post mount to flat mount with the wolftooth adaptor... Which also means changing from a 160mm rotor to a 180mm... Neverending
Of course! Talk about a blast from the past - good for you to check back in with us. Also 'good' to hear you're riding well, even with the accident. Good to see you making progress back, keep it up! And keep coming back here - you're one of the 'originals' in my little world of Cycling and this forum
Great ride, well done!
As the others mentioned, they might/should be just long enough to swap over - they don't look to be integrated in stem/bars looking at pics on the Cube site. You'll have to re-wrap/replace the bar tape, fairly straight forward & easy to do (just wind it back to the shifters). Re-route the hoses - you'll probably have them crossed below your bars (unless already crossed so uncross), so figure if you want that before the screw in bit holding them in place, or after it. But make sure they don't snag or pull when doing that (& when steering).
I don't know 'how' SRAM hoses fit into shifters, but certainly Shimano the 'olive' and barbs used are '1 fit' to the hose, then are quite easy to move around. Almost impossible to remove the olives to refit them, usually need to cut them off to get them through a frame hole. But looking at the build on the Cube website you shouldn't need to.
Kinda easier being double sided, but also they feel 'small' compared to SPD-SL. If you're used to the much wider and more secure pedals of SPD-SL & Look Keo, you'll find you have to 'hunt around' to find the pedal and push the cleat in straight down - It takes more than the 'habit' you may have of finding the front 'just below your toes' and pedal into them like SPD-SL...
I’m just going to go for a quick ride around rather than my usual 30km daily route with the brakes how they are and get the bits together in case I do need to bleed brakes etc. I’ve done a lot of work on my own bikes over the years but somehow never re-wrapped handlebars but that should be easy enough.
The shoes I ordered are way too tight so they’re going back for a size up, my SPD-SL shoes are the same size so it’s probably a manufacturer thing (Northwave existing vs Shimano new)
Did a bit of clipping in / out in the garage and yeah I’m just not familiar with where the cleat is on my foot as it’s smaller but I’m sure I’ll get the hang of that
