Nice - we should friend up !
We have similar systems too![]()
Does everyone get the CPU issues, or is just specific ones?
Seems to be high end CPU's
Yes , i have the same CPU and usage dropped by about 30-40 percent with this fix.Does mine fall into that category (7800x3D)
Not sure but me and MRK both have the same CPU (12700k) and for whatever reason his was affected but mine wasn't.Does everyone get the CPU issues, or is just specific ones?
The depressing downers in this thread WTF. This is the best FPS we've had in years. Some people are just never satisfied![]()
I did a few hours of play last night in a squad with my son, me on PC and he's on PS5, and I found some frustrating stuff on my side.
- It often felt my gun was firing blanks - so many times I'm multi click burst firing zoomed in on opponents and it appears like nothing is happening. Felt like I should have got the kill but didn't.
- I was getting shot and killed when clearly behind a wall and out of line of sight. This happened many times. I would retreat to cover behind a wall and then die with the red outline of the person that killed me a long way behind the wall.
Overall we are liking it so far.
We are both completely new to Battlefield so there is lots to learn but getting there
What GPU is it you are using? Edit sorry 7800XT..I'm getting about 80% CPU usage, Ryzen 5800X, i applied the user.cfg "fix?" its made no difference, still 80% and the same performance, but i expected that and the performance is good, the game is butter smooth.... so isn't this just normal? Its a very well optimised game making use of all 16 threads, that's all it is...
Look at the frame time graph on the OSD, you don't get much flatter than that...
I never seemed to get to play in attack Heli's in BF4, you'd always have them being taken and kept by the same players all game.I love attack helis.
But the way they spawn right now leads to 90% cases of single pilot without a gunner. And predictably die in 30 sec.
In 4 days I have seen one (1) enemy attack heli surviving and harassing long enough to make a difference. Zero on my side. And this is where barely any engis carry AA missiles.
A fellow 5800X user is saying its unplayable for him with a 5070Ti.
5800x bottleneck for 5070 ti
I'm unsure what to do, I recently purchased a 5070 ti and replaced my 3070 fe ready for Battlefield 6 release. However, playing the games I have installed now has showed me how rough this CPU is. I was told 5800X3D allows me to stay on AM4 but I can't find it to buy anywhere, I can't afford AM5...forums.overclockers.co.uk
I was playing Battlefield V this week and my GPU reaches 40% usage and my CPU reaches 75-90% usage and I get fps drops from my 157 fps cap to around 110 and it's horrible
My FPS range from 180 to 110, but that's the full range of performance and my GPU is always at 95% +
Also he's talking about BF5, not BF6
He does have a much more powerful GPU than me, 5070 Ti vs RX 7800 XT, also, and i'm not making this in to an AMD vs Nvidia GPU argument but AMD has a much lower driver overhead than Nvidia, AMD's GPU's have a sort of 4 to 8 core CPU built in to the GPU, they are called ACE units, they are effectively CPU cores which are used for GPU thread scheduling.
Nvidia use your CPU's cores to perform the same task, taking CPU cycles away from your CPU that could be used for the game, tests show Nvidia can be as much as 40% slower than an equivalent AMD GPU when CPU bottlenecked, so a slow CPU can be that much slower on an Nvidia GPU vs an AMD one, an Nvidia GPU is probably not going to get the same level of performance i'm getting with my RX 7800 XT with the same CPU even if the GPU is much faster.
Ok, personally with a GPU like the 5070 Ti, its such a powerful GPU that i would want to upgrade the CPU to be honest, or cap the frame rates to 120, that would fix the wild FPS swings.
getting old since beta? it is odd.. I've not played bf since 3 so I thought it was just me but it's broken, something somewhere isn't right. I'm sure it'll be fixed but interesting to see that beta was better.I have no idea what I'm doing wrong.. really enjoyed the beta..TTK, hit reg etc all seemed super great... now.. emptying a full clip with hit markers to be span on and killed within 4 bullets! I'm getting old.
good they are the bane of my life took a few out with rpgs the less helicopters I see the better.
