I got confirmation emails straight away for both orders. One just sat processing for 10 days though. The other dispatched after 2 days.Ah ok thanks. Yes they've taken payment.
Did you get confirmation emails at all as I've had none?
Watercool itWell my 5090 has started having fan buzzing issues... again... this will be the 2nd time doing an RMA for the same exact issue. Card is fine but the company Zotac sources their fans from seem to be cheap crap.
Man that's such a PITA for such an expensive card eh. Grr.Well my 5090 has started having fan buzzing issues... again... this will be the 2nd time doing an RMA for the same exact issue. Card is fine but the company Zotac sources their fans from seem to be cheap crap.
Watercool it![]()
What ever you do don’t skimp on lubeI have bad luck with tech in general, Adding WC into the mix would be like walking into a thunderstorm with a 50 foot tall conducting rod and saying "I'm totally safe"
It seems to have sorted itself out for now, Maybe some lubrication finally got into it.
I'd try the other monitor. DP can be funky with certain standby implementations I know. It's also true it can just completely get "hidden" to the GPU. Something that always used to bother me personally was programs like AnyDesk and a previous DP monitor(funnily enough think it was also gigabyte!) - you had the leave the monitor on else trying to remote into the PC would cause you to get no desktop due to how the software worked and the fact that the GPU couldn't see the monitor anymore.So just installed a new 5080FE in my secondary machine.
To cut a long story short, I get no output at all when connected via DP but it's fine on HDMI.
After a bit of Googling, it appears this is a known issue whereby the card doesn't detect the monitor when it's in standby.
A few people have recommended using the monitor's OSD to keep it "alive" while the computer boots but this doesn't work for me.
I'm thus stuck with HDMI which is unacceptable as Freesync doesn't work over that connection.
Does anyone have any ideas?
Is this a monitor specific issue? I have a fairly cheapo Gigabyte G27Q.
Yet to try connecting it to my other monitor to see if that works.
So ordered an FE from Nvidia two days ago. No confirmation emails whatsoever and order on their site just says 'Processing'.
Is this normal?
As the card is out of stock again, I'm now questioning whether I've actually been allocated one or just gone back into a queue?
Whole system is garbage compared to the old system used for 30 and 40 series cards.
(Hope this doesn't violate competitor rules as OcUK don't sell FE cards).
Hopefully the supers are incomingI was just being curious to see what the price of FE cards are going for on the Nvidia site and there are no FE 5080 or FE 5090 listed. No "out of stock", just completely missing from their site.
I wonder if they've stopped making them now.
Hope so, I've been holding off making a purchaseHopefully the supers are incoming
A good firm tap can sort all sorts of issues out.
That's a good point. Would there really be a 5090 Super? That would some thing!
£909 for the 5080 FE and £1799 for the 5090 FE. As others have started, they now only show them on the site when in stock. The supply has certainly dried up versus a few months ago.I was just being curious to see what the price of FE cards are going for on the Nvidia site and there are no FE 5080 or FE 5090 listed. No "out of stock", just completely missing from their site.
