Caporegime
- 9 Nov 2009
- Planet Earth
The Tamron 17-70mm F/2.8 Di III-A VC RXD is £433 on Amazon.
Never heard of Viltrox, thank you. I'm currently looking at X-S10 and XT3.Received the Viltrox 9MM last week after pre-ordering it from AliExpress. Will be interesting to compare this with my Fujifilm 8MM.
Fujifilm does not have as many third party options,but Sigma and Tamron do make some of their lenses available. The best value third party option is Viltrox IMHO.
X-T3 would be my pick, just for the top dials and retro aesthetic. S10 to me loses some of the Fuji charm with its regular camera controls.Never heard of Viltrox, thank you. I'm currently looking at X-S10 and XT3.
Check the Fuji Refurbished store for some good deals.Never heard of Viltrox, thank you. I'm currently looking at X-S10 and XT3.
Can you not reprogram the focus to another button?X-S10 is a more modern camera with X-T4 internals (and IBIS too, it is like the cheapest IBIS body you can get in the lineup that has quite modern internals besides the XH1 which is a couple gen older, like XT2 era) but what really annoys me from Day 1 and never got used to is I was unable to reset the focus point by pressing down the joystick. Not sure sure Fuji did that.
Can you not reprogram focus to another button?
I am leaning towards the X-T3 still looking at the nikkon aswell to many choices!X-T3 would be my pick, just for the top dials and retro aesthetic. S10 to me loses some of the Fuji charm with its regular camera controls.
So went to a camera store and felt both the X-T3 and X-S10, I really liked them both. The X-S10 felt great in the hand with that thick grip but I loved the knobs on the X-T3 and the fact has weather seals...does anyone have grip for the X-T3 that make is feel like X-S10?X-T3 would be my pick, just for the top dials and retro aesthetic. S10 to me loses some of the Fuji charm with its regular camera controls.
Thats big oversight seeing that you customize a lot of the buttons..It is set and FIXED that reset to the BACK button. It's the bottom button on the back. The issue is 2 fold. 1, every other camera I have, both Fuji or Sony, let me reset the focus point to center by pressing in the stick. So muscle memory has already been there for decade of use. 2, that button is totally flushed to the body, so it is almost impossible to press it when i want to by feel every single time. Whereas I know I have my thumb on the stick every single time.
I have looked into remapping it, and trust me, you can't. I even spoke to Fuji rep at the photography show and moaned about this to them a couple years ago. They could fix this with a firmware update but it's not going to happen now.
Jpeg or raw? If raw, what software are you using? Adobe demosaicing of Fuji raw files is terrible. They are much cleaner when processed through Capture One, Irident, DxO etc...Hey guys looking for some advice here. I got my X T5. I've noticed that every image I take seems to suffer excessive noise. I'm not used to that. My X T3 with the same settings, hardly produced any. So I gather the improved sensor is creating more noise for me? I'm wondering if I've made a school boy error or I've forgotten a setting or something. It's a bit odd.
If jpeg, make sure grain is set to off.
Can you post some samples?
