Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
What about Sony EV-10 ?
If your vlogging just use your phone + gimbal. If vlogging at home/studio, then get some LED lights, & DJI mic mini.
The above would produce better results for everything but photography.
The A7's tend to overheat doing video. To make my A7IV work, I had to have an 80mm fan blowing on the back of the camera.
If however you are serious about photography, I would use a dedicated photo setup.
Yeah. If you get Blue Light discount its cheaper from Panasonic direct:This one.:
Panasonic Lumix S9 Black + 20-60mm Lens
The Panasonic S9 in Black with LUMIX S 20-60mm f3.5-5.6 L-Mount Lens (S-R2060E) is the Lumix S9 camera body in black, with the Panasonic Lumix S 20-60mm f/3.5-5.6 L-Mount Lens (S-R2060E), supplied as a Kit. The Panasonic Lumix S9 is the smallest and lightest full frame mirrorless camera in the...www.ukdigital.co.uk
Where will you be vlogging? What kind of vlogging?
No I mean will you be action vlogging outdoors or just sitting indoors? Very different vlog cameras would be needed.Mainly on YouTube.
Sorry I’ll be vlogging outdoors.
Maybe take a look at GoPros then. The GoPro Hero is £169.99:
I would buy separates, i.e. a cheapish vlog cam and then a proper camera for photography.
Do you really want to hike with a 5D?
If you’re going to buy then use OnBuy and buy it brand new cheaper.The bag I use is pretty big. I rather buy something that’s quality and I can upgrade with lenses etc.
