- 5 Jul 2003
- Cheshire
Also, some light reading for you guys..
Our proposal
To control excess emissions from in-use vehicles, we propose to make it a legal requirement that all road vehicles in-use in GB from 1 January 2001 must have their ECS maintained in such a way that the maximum level of emissions and other requirements of the control system continue to operate as set by law at the time of manufacture.
We intend to update regulation 61A to make use of existing sections of the Road Traffic Act 1988:
Depending on the circumstances, breaches of these sections can result in fines of between £1000 and an unlimited amount following successful prosecution in the magistrates’ court.
- section 42: use of a vehicle that does not comply with construction and use requirements
- section 75: alterations to vehicles
- section 76: fitting or supply of unsuitable vehicle parts
This means that the following will be prohibited:
We have chosen not to distinguish between excess emissions caused by poor maintenance of a vehicle and those caused by modifications made to vehicles.
- using a vehicle on the road which has been maintained or modified in a way that means it no longer meets the emissions standards that it was approved to
- allowing a vehicle to be used on the road which has been maintained or modified in a way that means it no longer meets the emissions standards that it was approved to
- modifying a vehicle yourself, or allowing a vehicle to be modified, in a way that means it no longer meets the emissions standards that it was approved to
Similarly, we do not propose to distinguish unintentional and deliberate modifications made to the ECS, nor whether these are through hardware or software alterations. The environmental and health impacts of excess emissions are the same, regardless of the reason. Such distinctions can also be difficult to evidence and would make enforcement unreasonably difficult.
We also want to encourage good vehicle maintenance, which may avoid more expensive repairs following catastrophic failure.
In short, if you own a vehicle with the dpf/egr system removed then it's time to move it on, so you aren't left holding the baby.
