- 18 May 2010
- London
That's not spammy.
If you need to do 1,1,1,1 for a combo but actually spam 11111111111111 you get penalised with more enemy aggression. Souls games do this, too. Timing is rewarded.
If you don't do any attacks at all, you'll notice that the enemies attack significantly less.
Your goal is to build falter to do an execution, then use enhanced damage to hit the bigger enemies and do more executions. You mix in abilities and status effects as required based on the enemy. Fire against mold, rocks/kinetic against armoured enemies. Mold against the
.hedron enemies
You can also use enemy attacks to your advantage. Example: the Hiss that fires a laser is great for wrecking other Hiss. Use your character to aim the laser and then stand behind what you want it to hit.
If you're approaching the game by spamming the scythe and expecting it to be easy, you're going to have a hard time. The scythe works really well with the fist launcher combo finisher. Once the launcher is upgraded it launches multiple enemies and then the scythe comes into its own with multiple enemies and aerial attacks.
I didn't know that. I was just launching in to fights 11111111111111, I didn't know the more you spam the more aggro....
I'll try tonight see if it makes any difference.
