- 20 Oct 2002
- Derby
yeah i have done that. I have a good amount of pla and abs so will rattle some out.
Ah thanks, do you know what model one you have?I have the sunlu one which was around £35, seems to work quite well. Couldn't believe that the PETG I bought was 58% humidity when it arrived, sure enough it did spit and split until I dried it to 20%ish, worked perfectly afterwards.
I'll probably buy another one at some point.
If you're in the Bambu eco system then the AMS HT is always an optionWhats everyones suggestion for a single spool (space is tight in the house) filament drier?
I didnt even know about that, is that a single standalone unit that dries but also would allow my A1 mini to print another colour?If you're in the Bambu eco system then the AMS HT is always an option
I started out with the Creality Filament Box Pro drier for my P1S, which is a single spool machine. Very simple to use and did the job - however the viewing angles on its LCD were poor and since I had it situated on the floor (at the time) I had to bend down to see the display. I have this stashed away when it's replacement below dies.Whats everyones suggestion for a single spool (space is tight in the house) filament drier?
Standalone unit that dries (including ABS and stuff that needs a higher temperature) although needs the AMS Hub on A1 series printer.I didnt even know about that, is that a single standalone unit that dries but also would allow my A1 mini to print another colour?
I don't think it allows a 2nd colour, as I think it would replace the existing external spool (but I may be wrong)
AMS Hub - A1 Series
uk.store.bambulab.com
A1 Series AMS Connection Guide
This guide covers the steps for connecting the A1 series printer to the AMS via the AMS hub.wiki.bambulab.com
(It is forward/cross compatible with all the "bigger" printers e.g. P2S etc so if you did upgrade later it's still compatible)
@Armageus do you use the HT? Need to grab a dryer and plan on adding the HT to a future A1 upgrade, if I grabbed to HT now can it be used as a standalone dryer?If you're in the Bambu eco system then the AMS HT is always an option
Unfortunately I don't think it will work as a standalone dryer as it needs to be connected and managed via the printer control panel.@Armageus do you use the HT? Need to grab a dryer and plan on adding the HT to a future A1 upgrade, if I grabbed to HT now can it be used as a standalone dryer?
Thanks mate, guess I'll need to get that upgrade sooner....Unfortunately I don't think it will work as a standalone dryer as it needs to be connected and managed via the printer control panel.
