Dashcams!
Just ordered it and it will be fitted on Dec 2nd.
My mate was going to fit it for £50 but I would have needed a £30 hardwire kit.
By the time I got other discounts it was easier to just let Halfords fit it and then it's all guaranteed etc.
Thanks for that @cadmunkey and in real life it's quite compact.
I read that halfords turn down dashcam fits to EV's even if you turn down the parking mode due to the 12V battery drain issues. Have they stated they will do yours?
Searching online I found lots of people who when booked in turned up to find they wouldn't fit it. Check before you waste your time :)
After ringing Halfords and then the fitting team they have cancelled.
I then moaned that when I clicked on Fitting At Home it asked for my Reg, it told me it was an MG4 Trophy Electric Car and at that point it shouldn't have asked me for a fitting date.
It's 12v the battery they are terrified of. The other option is a next base one from their website with home installation. They will do ev's.
Apparently there is supposed to be a Parking Drainage problem from the 12v battery so you go back to a flat battery but that seems to be wildly exaggerated.
Halfords won't even fit using the lighter socket so it only comes on when you turn on.
