**Bioshock Technical Thread - Not Official**
SkeeterPSA said:
Nice, so er how did u get it workin.
This way;
To get AA working on nVidia cards right click a shortcut to BioShock go to properties and at the end of the "target" field type in the following: "-dx9"
This forces the game to run in Dx9 and enables the use of AA when forced, I couldn't get AA to work by disabling Dx10 via in-game this was the only way.
When you've done this go to the nVidia control panel or nHancer, select BioShock and override the AA settings to whatever you like.
Just so you know I've tried it with standard 16xAA and it works, though it looks a tiny bit worse than 4xSupersampling.
Am having problems as well with Vsync on this game with my 8800gtx,,,Shows up really bad on dell 24" monitors.. (this is with the bioshock demo)
Played the demo and ok here on gts8800 with forced vsync on and no tearing so must have been working.
also using recomended beta drivers.
cheers.
In the graphics options, I turn up the brightness a little bit. But when I exit the game to windows, everything is brighter than it should be. Any idea why windows stays brighter after leaving the game? Only way to get back to normal in windows is to reboot.
Whats the best to set the tool to for FOV... at the mo I have it at 0.75 for 16:9
Monitor is samsung 226bw res @ 1680x1050.
I keep turning off V-Sync before I play, Accept the setting then have a game which is perfect. Quit BioShock load it up again and V-Syncs on again!?
It keeps turning it self back on. Anyone else getting this?
