Yes i'm on 1.1.4 and o2 PAYG, I have tested a Orange and Virgin sim and all work fine.
All works perfectly.![]()
Well it all works fine so I don't see why it would be a problem.
Also, the locate me feature in maps.app works properly now.
Anyone use ZiPhone on OS X when they did it?
Reason I ask is because the majority of people seem to use the Windows version, and the UI looks vastly different; no one seems to have mentioned.
I'm just testing this on a 16GB iPhone using OS X, incase people need a report
*Justin, cheers for adding those pictures to the sticky*
May I ask what has changed? Is it a jailbreak issue or does it work better now?
No probs mate.
Yeah I used the OS X ZiPhone, works fine.
Yup, would be good to know if it works on a 16GB too.
It never used to work before because of the baseband version, but now that it can be updated and unlocked it works properly. You used to have to install something else to get it working and every time you restarted your iPhone it would stop working again.
How do you get the 1.1.4 Ziphone GUI client?
So what baseband version do you end up with? Must admit, I'm not really following this baseband and bootloader malarky.
