- 24 Jun 2021
- Oxon
Very good point.Plus apparently their RTX3060 is "4GB" - makes you wonder whether they have one of those China special rebranded Fermi GPUs.
The Ryzen 2600 has a lot more resources then a i7 6700k.
The memory is a good point although 4gb at 1920x1080 should be enough for most settings. This might not be a RTX 3060 but it still wouldn’t explain the 100% CPU usage which would point to this being an RTX Ampere card which is a resource hog.
Very good point.
And I would ignore similar people from the opposite side also. I’ve noticed one in particular, begins with D, and ends with e, sounds like rave
There are options the OP has from both AMD and Intel.
This one side is better than the other, is ridiculous. Both have their strengths and weaknesses.
It doesn't matter in GTA V. I had a Ryzen 5 2600 and a mate a Core i7 6700 - the latter was quicker in those sorts of games and we had broadly similar dGPUs. If an RTX3060TI and a Ryzen 5 2600 can produce nearly 90FPS~100FPS at 1080p,then an RTX3060 and a Core i7 6700K,shouldn't be having issues "reaching" 30FPS. If anything the RTX3060 has less shader units,so will have less issues with slower CPUs.
Also,the RTX3060 4GB is more indicative of a faulty dGPU or more likely a fake RTX3060.
What about the option of actually fixing the problem,instead of people here asking the OP to spend £100s they might not need to do!
Some on here must never ever play a single game,to think an RTX3060 and a Core i7 6700K is incapable of actually reaching 30FPS at 1080p.
People need to actually read what the OP is saying,and the information they posted.
Did you both have Ampere based cards?
Hmmm because they are the only chips worth buying unless you want to step up to Threadripper.
rubbish some of the i5 chips are excellent value The I5-11400f is the best mid range cpu out there and the i5-11600kf is excellent as well
People once were that way about intel products.. (some maybe still are)
AMD are better at the higher end but in the low/mid range of CPUs it's Intel that offer the better performance per $ spent.Are they? Pretty sure you can buy more performance form AMD and on a better platform.
TBH I’m pretty shocked that two users, maybe even three! of this site struggle to understand why someone would consider AMD the only CPU option. AMD have been outstanding. Years ahead of the competition in every metric and the obvious choice.
You’re talking about the vapourware 11400F again.
AMD have better parts at the low end and on a much better platform. 1600AF and X570 for example.
for most users
not really a i5-10400f can be picked up for £120 on average with a b560 motherboard all cores 4ghz and 3200 or 3600 memory and its comfortably faster than a ryzen 3600 ( which i will add is min amd spec for battlefield 2042)
Really, really? or upset how poor Intel are really?
It's a waste of time arguing with Jigger, he has shares in AMD and a poster of Lisa Su on his bedroom wall.Iam not loyal to either of them
but it in this case its a fact
