Don
370mm insulation?
Are you going to use xl loft legs then?
OMGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG370mm insulation?
I have a mask - and have ordered dust sheets and some masking tape. I shall get the Dexter murder suit for when I tackle the insulation though!You're going to be busy then @dLockers! Not sure if you said about getting a mask or disposable overalls? It's going to be a dirty job for sure.
Well done good job. For levelling the hatch you can get some shims like these:Had a decent go today, half as much as I'd have liked but there we go...
Firstly I cleared off the old 20mm insulation layer and bits of old carpet. Found this poor chap:
I then bagged up downstairs with some super inexpensive dust sheets. Life saver:
I drilled a pilot hole to identify where in the bedroom the hatch would fall. Luckily it gave me enough clearance from the rear wall to accommodate a wardrobe. Annoyingly not quite enough if I ever decide to do a wardrobe on the left hand wall as pictured above. C'est la vie.
I then whacked two supporting beams in, and put 2x 2x4's the long side of the opening.
Joining up the four pilot holes gave me my outline. I tried to use the multitool but it was ungodly messy and didn't cut deep enough at all.
In spite of having several 000's of pounds of tools, the 40 quid Bosch jigsaw came into its own.
Now I had my aperture width sorted I went about removing the ceiling joist. I left 45mm for the 2x4.
Great success... some decent damage to the ceiling but nothing that the frame won't cover.
N.b. I closed the gap by 20mm with a bit of old floorboard.
Reasonably clean cut.
Frame up. Now annoyingly I didn't realise how much of a PITA these insulated doors are. You need basically a perfect ceiling for them to close succesfully first time. Unfortunately my frame is not quite spot on, so that is a job for another day... not sure how I level it off tbh.
Fin 1
Fin 2
I'm pretty sure I should have doubled up the new opening, so without the doubling up I put some spare 2x4 pictured at the bottom in the image above. It doesn't quite span 3 joists so I think I'll grab another length of 2x4 and frame the entire thing.
As you can see the insulated door fits pretty well. We'll see how cold it gets this evening as there is now zero insulation and a loft hatch in the (current) bedroom.
Plan is to get some decent ladders if I can't recover the ones I already have, so that the loft is a truly usable (storage) space.
Questions for the audience!
I have a whole bunch of twisted ceiling joists. It certainly isn't new twisting. What's the guidance for fitting loft legs?
Top man, good shout. Those packers look like a decent solution.Well done good job. For levelling the hatch you can get some shims like these:
Broadfix Assorted U Packers - Pack of 150 | Wickes.co.uk
Broadfix Assorted U Packers - Pack of 150www.wickes.co.uk
Come in various sizes I used these for levelling my suspended floor in my downstairs bathrooms, very handy.
Giving me heebee jeebees with you standing on that board in the last photo
For the legs on twisted joists I’d just crack on unless they’re massively out, it’s a loft floor, unless you plan to store some bowling balls it’ll be fine. Or again you could use the shims on the top of the legs when you put the boards on top of them.
I would recommend the same but he has laths as well so not sure how well they’d fair really.Good job @dLockers, not wasting any time!
Might be a bit late in a few of these recommendations but for cutting plasterboard next time get one of these, an Irwin jabsaw, brilliant it is. I even used mine to cut circles in the ceiling for speakers.
If you're vacuuming in the loft you don't want the vacuum cleaner in the loft as well as it can disturb the air, increase the heat and noise. What I did was get a hose extension so it could sit in the room below and controlled it with a smart plug.
Once you've packed the loft hatch give the edges of it run with some caulking if you aren't already.
I would insulate under the water cylinder as if you don't it'll create a bit of a cold spot in the ceiling, otherwise it won't too any harm.
Yeah that's exactly how I found myself working too. Super sturdy. Definitely OTT with how many I have under those boards, may try and space them a bit more when I do the other side. I need to tott up how many I have as well. Think I may have way too many or not enoughGood job. Legs tougher than you thought they'd be? I'm a big chap and after I got my first board down I laid down on it and was surprised by how sturdy it is. Also when screwing them down I'd often put my one free arm on top of one putting a lot of weight on it, and drive it with the other.
I didn't do any more legs than needed except around the loft hatch, I figured that part is probably going to get abused the most, people tricep dipping in and out.
