- 4 Aug 2007
- Wilds of suffolk
Will they loosen up and come free easily when they ripen? First time growing chillis.
Guy at work grows loads and gives some away each spring. Our apartment is great as they live on the east-facing balcony in the sun all morning, then I move them over to the west-facing sill on my lunch break. With these temperatures they've been wilting every day by the time I get home from work to water em, but I've heard that's not a problem? They seem to perk up fine.
Tempted to move them to bigger pots as they've grown pretty rapidly, or is it better to do that after growing season and let them fill out their roots over winter?
Personally I snip mine off with scissors. The sort of umbrella shaped bit that attaches the chilli to the main plant will get thicker as they grow.
Technically yes they will just fall off when fully 100% ripe, but we really want them not quite 100% ripe.
Chillis cope well with lack of water, as long as the roots don't utterly dry up.
You can repot now I would say, if your over wintering some will trim back the roots anyway. Good luck with this
Awesome. Just repotted and they came out very easily and like you say loosened them up a bit and then watered with tomato feed.
Fingers crossed they perk up a bit.
I've read about over watering... But watering every day in this heat (plants in direct sunlight) is a must surely? They end up looking very dry otherwise.
Overwatering Chilis is the same as any plant. You do not want the roots to be fully submerged for a sustained period of time, as they will basically rot. They need oxygen as well.
Its only really an issue if you have them in something that will not allow the water to drain away in my experience.
Also consider that allowing water to drain away will also wash away the food in the peat, so try to only water what the peat/mud etc will be able to absorb.
My biggest cayenne last year was about 1.25 meters. It produced around 75 chilies, when I pulled it out at the end of the season it had a rootball about the size of my fist.
Chilies are used to harsh conditions, they will cope fine in poor soil, with dodgy watering, and low nutrients. You can max all those out, and get a bigger crop as long as you don't go crazy on any.
I probably watered my chilies more last year than ever, even twice some days and got my best ever crop, but they were in my poly which would hit 45 degrees so its a hard comparison.
