Just got the Palit dual and it is anything but quiet!
Got mine set in afterburner to 73 degrees max temp and the fans never go above 50% so I never hear them. Ive got no mech drives in the system plus my Corsair AIO is set to silent and all my Corsair MF140mm fans are set to 40% so any changes in volume to my already quiet system stand out a mile.
How high are you fans turned up? Its quiet because you dont need to turn them up given how well it cools itself.
It's possible that the noise is coming from the other bits of the system, in the end. The Palit Dual has quite a chunky cooler (which is good) but it completely covers the X570 chipset fan, which is working it's tail off at 4200 RPM to try to get some air through...
Isn’t that so quiet because you’re underclocking the GPU? What clocks does that boost to?
My Zotac Amp never goes above 72C when clocked at 2100/8000, usually sits at 69C, but it’s set to max temp 87C.
No underclocking dude. Wasnt aware you could actually lesson performance on purpose? What kind of blasphemy is this you speak of?
Seriously though, I have a token +50 added to the core in afterburner. Cooling is awesome in my case with the Corsair AIO Rad at the front cooling the de-lidded 8870k and three mf140 fans exhausting on the top of the case and another at the rear.
I'm more than happy with a token little overclock on the card and the 2080ti has been chewing through everything Ive thrown at it in 4k with settings the way I like them. Don't like depth of field and no need for high AA at 4k.
Sry, not been on this site for a while, FTW3 ultra.what FTW till you get?
I think people shouldn't seek shopping advice from the 2080ti demographic (no offense). Clearly these people aren't fiscally constrained and tend to a maximum when it comes to building gaming rigs.
Nearly went for EVGA but wanted FTW3 Ultra Gaming and couldn't find it for decent enough price. Have ordered the Zotac AMP with 5yr warranty
Good choice mate.
