2700x CH6 Overclocking help
19 Dec 2005
Hi All,
Looking for some assistance struggling to get this thing stable.
Bios 6004 and leaving everything as apart from setting ram to 3200 or above it won't pass stability tests.
Going to give it another go tomorrow when I get time and looking for some input or advice on process.
I was going to leave it all auto and make sure the cpu is stable with ram at auto and go from there.
I ran my 1700x at 3.9 3200CL 14.
Thanks in advance
you might need to wait for another bios update before you can run ram at full speed again. i have CH6, x370 gaming 5, prime x370 pro and the CH7 and i cant get ram to run as fast on any of the x370 boards as i can on the CH7. they are anywhere from 200-500mhz below the x470 board. i would expect this to be fixed in later bios's as the ch6 and ch7 are pretty similar boards.
for now run 3000 or 2800c14 and push the cpu clock on your 2700x, so you should still get more performance than your 1700x
This
This sounds sensible
I hope so I don't wanna have to get a x470 if I can help it.
Thanks
Quick update:
Everything is fine at 3000Mhz/CL14 so I'll do as suggested and wait for a new bios revision.
I was so dead set on 3200 as a minimum it became disheartening and you begin to question yourself etc.
Thanks
Further update: getting lag spikes/frame drops? I hope a new bios arrives or I'm going back to intel :(
Still getting weird behaviour/slow downs in games - running CPU at stock / ram at 3000Mhz.
Anyone else having any issues with their 2700x setup?
My impression with the 2000 series and RAM.
They might be better. But that doesn't mean it's plug and play. You've still got to find the magic combination of settings in the BIOS.
I read recently that AMD still have a lot of work to do with ram DOCP. Lots of settings are hidden and may not be correct when set to auto.
You also need to buy the right ram.
Even with 8 Pack Samsung B-Die I'm having issues.
Probably better with the X470 boards.
YMMV.
YMMV.
To be honest, if anyone has the 8 Pack B-die they should use Manual instead of DOCP. Then set ram speed to 3333, go into the ram settings and select and load "The Stilts" safe B-die 3333 timings. I'm running 4x8Gb sticks in my CH6 and it works without any issues at all.
Have had zero issues with the 8 pack ram, have ran it from 3200-3466 on C14-C15 using Stilts timings no issues on a 1700 and now a 2700X.
That’s useful advice, is it much faster than 3200c14 in reality ?
The Stilts safe 3333 settings are 14-14-14-30-52 the same as 3200c14, so it will be a bit faster yes. The same settings work up to 3400c14, that's on the CH6 running 6004 bios. If i can do it with 4x8Gb sticks, then it should be a piece of cake for anyone running 2x8Gb sticks. The most important thing is to leave SOC on Auto with the 2700x, setting SOC to the usual 1.1v results in errors when running Realbench, Prime95 or OCCT.
I'll give this a go later. Thanks
I'll try this when I get home.
3333MHz 14-14-14-30-52 1.35v or does it need more??
SOC on auto.
What I have found with my CPU is unless I add LLC 3 on to the CPU my ram isn't stable.
CPU is at stock.
SOC on auto.
CPU is at stock.
When you load the stilts safe settings, your ram voltage and ram boot voltage will be set to 1.4v don't change it. Same here as well, CPU and SOC LLC set to 3. It was the same with the 1700 as well.
