So you're saying no matter what the serial number, VISION cards are all fine? (my serial is 2038)
Yes
@GIGA-Man i know its a different question but will the 3070s have the updated power connector from the get-go? or they will come in with the concerned ones.
Currently yes, all the new connectors have this. My only worry is in future, even though the new connectors currently have the shrink rap, if there is no shrink rap it could confuse people.
This connectors are not to be bought anywhere, it needs to go to gigabyte for replacement.Hello gentlemen.
Does anyone here know of somewhere to buy a new power connector for this card? I can replace it myself but I have no idea where to search for spare parts. one of the pins keep getting pushed in, and i see several others that arent properly lined up.
Maybe @GIGA-Man knows something? I live in Poland so i am completely screwed for options.
I've got the Gaming OC, and the power connector is a mess....
3-4 days depending when do you contact gigabyteReceived mine this morning from a different supplier and it had the power connection issue. Thought it would try it in the mean time and one of the pins has been pushed back. What’s the turnaround in these being fixed in the UK?
mines was collected Friday and returned midday todayReceived mine this morning from a different supplier and it had the power connection issue. Thought it would try it in the mean time and one of the pins has been pushed back. What’s the turnaround in these being fixed in the UK?
Hello gentlemen.
Hello guys i am from Austria i will get my Gigabyte Oc Gaming 3080 this Friday. And now im a little bit concerned. If i get the faulty version what can i do from Austria ? Sent it back to the retailer? Or gigabyte or? Lets hope i get the fixed version.
Also thank you for this thread as you guys are the only one who made one about this topic i saw the problem in a few german forums but nothing major like here, thats why i found yours but 25 sites and an Official giga Rep guy i had to sign up. Also The Sopranos <3 i saw Tony and yea
Welcome to the show ..
I would suspect the card you will be getting will be above WK38 on the serial number which would be fixed..you can check once you receive it and then take it from there if its WK38 or below.
Nope
you'll likely get it back Friday, unless they repair it todaySent my card off which was collected Tuesday and tracking says they recieved it Yesterday (wednesday 21st). Will I recieve a confirmation from Gigabyte? Whats the expected turn around?
