We have investigated the issues that have been reported and have a solution to fix any cards that have developed lose or faulty power pins. Any customers that have experienced the same power connector problem as reported on this thread, please contact me directly and I will arrange to have the card fixed with a new connector as quickly as possible.
[email protected]
@GIGA-Man Does this problem also affect the Aorus 3080 master?
@GIGA-Man Thanks for the proactive and reassuring response.
I'm sure you cannot go into too much detail but could it be possible that this solution could be applied by the end user at home (after obtaining permission) without having to have the card doing a round trip back to the manufacturer?
To my mind it is a bodge and I would not want a gpu with this on it
Future cards will have the fix, if you do have a card with an issue as there will be a small amount of mixed stock, contact me and I will make sure to get it fixed for you.
Fair question, let me check. While it's a fairly simple change, doing it yourself could void the warranty if you damage the card. While I'm sure you and almost everyone on this forum are more then capable, some please should not be let near a screw driver and PCB.
For those of us who might receive a card from the mixed stock and find that they have the unmodified connectors, would we be looking at returning it to base for modification and waiting to receive that same card back as opposed to having a straight swap to avoid downtime?
Thanks for the updates .. So to be clear.. the original design of the connector block are defective.
But as since been revised fixed going forward.
Now i understand not all will have the problem on the original flawed design but i would guess eventually they will ..the more times the user unplugs re plugs back in ect ..
However what i am really concerned for is for the people that are unaware of this issue
and lets say some of plugs connectors do not make good contact with the pcie lead connectors but still work .. so over time as we have seen in the early post of this thread where the connector melted due to resistance building up.
Then surly this is a serious issue and could lead to something worse. then i would expect gigabyte to recall the cards that have the defective blocks ..as the last thing anybody wants and in the worse case is a fire on there hands.
So is there any other cards in the range with this connector issue other then the ones i have listed ?
Vision has exactly the same layout so I would suspect early ones have the same issue.
I also recieved a card with loose power connectors, and I've contacted my retailer for an RMA and hopefully a replacement. Seems like there are no replacements around and they're not expected until 2021, so they've decided to give me my money back. For me that's an absolute bummer, especially when i read that gigabyte are working on replacing the faulty cards as we speak. I'm from Norway though, and we don't have any official Gigabyte rep here, but do you think you could help me out in this situation? I would be very, very grateful. Thanks
@GIGA-Man thanks for keeping us updated
Oh, I almost forgot. All card now being produced have a new connector.
Any others that have the old type and that do develop a fault let me know.
