3080 FE Thermal Pad change: Mem Temps still 100c!! Help!
Is there a way to save the original thermal pads if I do need to RMA/warranty this card?
Now I've got all the pads in, I'm wondering if I really care enough to repad when I could just sell for a profit and carry on on my Strix 2080 Super.
Very hard to keep them looking like my earlier photo. Use cotton thread to slice it off.
What waterblock did you use? is it the EK one?
I looked at that one. But I went for Corsair in the end as it was in the BF deals for £95 I think.
Looks nice and temps are unbelievably low. EK might be better to those more knowledgeable...but I'm impressed.
Yeah I am looking at that as well. Ek ports are in a different place to previous blocks so my loop would look odd unless I go with the Corsair or alphacool equivalent.
I had nothing so went all Corsair. Probably a bit "mainstream" and those in the know prefer something else, but so far so good.
Hi all so I am reading this with the words bugger.. so can you’s confirm new 3080fe need front pads at 1.5mm. I say this as I did it same as my old one with 2mm and as you seem to be saying gpu shot up tried pressing in pads a bit not joy if anything they went flat and the vram went up also..it’s a new 3080 2 month old, so I’d say something has changed?? The sliver plate the chip sits in is smooth but with a pattern on it now. So just checking it’s 1.5 front and back plate 2mm gelid ultimate thank I’m advance strange why it’s changed though…
MX4 and in gaming I'm getting lower core temps to the tune of 5c, same for hot spot. With an undervolt for 260 watts at 1840Mhz temps are like 55c on core and 70 mem in control, well impressed. This with fan set to 45%.
Tested port royal, 5 loops stabilized at temps shown in screen.
Update, 5 months on Vram temps are still good but GPU hot spot is now 20c hotter than GPU temp, so 67c in game is now 87 hotspot. I guess this is the MX4 at fault, anyone recommend a better paste for the 3080?
Well, I did the 8080
that will most likely be the pump out overtime the die isnt totally flat its slightly curved
Its recommended to use thicker pastes , like Syy 157 or TFX Thermal Paste I myself used Syy 157 its cheaper and not noticed any difference with hotspot in 5 months the delta always is 10c-12c
Also recommend spreading the paste isnt the easiest paste to spread but once heated using hair dryer to heat the tube does make it easier
Syy 157 applied and yeah 10c difference between GPU average and hot spot. Just reused the pads that were on there, they fall to bits at the slightest touch but mine were still intact, just about.
Took some pics of the MX4 after 5 months use, and yeah not looking good.
I just redid my loop and used...MX4 since it's all I have. I did get some similar increase in hotspot temps on the loop before from 15-25C delta over GPU temp in about 8months. Didn't notice anything looking wrong with the paste on removal though will keep an eye and if the delta rises again I'll try out the syy157 stuff :)
I'm now 5 months on from changing the thermal pads, and repasting the core with Noctua nt-h2.
Memory Junction temps get to 82C, Core gets to 63C, and Hotspot temp is 76C.
So things seem to be holding up quite well, my temps are quite consistent and looks like a nice long term solution for keeping the temps in check :)
Don't mean to necro, dunno if this thread is old by your guy's standards. But a google search brought me here, and well I had to make an account to add my two cents for any others potentially in the future that were in the same predicament I was in. Was running into issues where my 3080 fe was throttling and even crashing in some games.
After a surface level search I found numerous posts/videos/reddit threads saying replace the thermal pads with 2mm Gelids extremes. Ordered those, waited the week or so for the ship and slapped them in 2mm front and back and had some xtm50 sitting around that I used on the die. Boot up, and before I could even start stress testing gpu temps go up 75c idle memory would hover around 80c and hotspot 102c.
I do some more searching find a few threads stating someone used 3mm extremes on the back, and that 2mm where incorrect for the back. I even worried that the Corsair thermal paste wasnt up to snuff. So I ordered another batch of pads and paste (2mm, 3mm, and some nt-h2) and waited for ship. I redo the front pads with new ones thinking I pressed them too much and handeled them too much with bare hands. And apply the new 3mm pads to the back of the pcb. Upon putting it back together it immediately felt wrong. The 3mm pads were completely too thick and would barely allow the card to come back together. Thermals were a bit better, but as soon as an application was ran and card was put under even the slightest load fans would ramp to 100.
****** the hell off, I kept searching. I eventually stumbled upon you lovely lot of people and start digging through this thread. At the suggestion of @Falkentyne ordered MORE this time some 1.5 mm and more 2mm. Also seen the mentioning of TFx which I threw that in for good measure. I followed the layout that was provided of how to lay out the pads (using different sizes in spots) on the front. Slathered that tfx on the die, slapped the back together with 2mm on the back. Temps immediately improves idle is down load temps are down. And the card is back to being whisper quiet.
Looking back I think It was solely me using the wrong sizes of pads not letting the die make good contact. That and the tfx was a great call. Thanks again and to anyone googling and stumbling on this forum. Follow @Falkentyne advice!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ps. heres a snip of thermals https://imgur.com/a/Qiegsh5
Another bump (sorry) just tried this as my ram temps were getting crazy. The core and ram temps are now much better but the hotspot is hitting 105c instantly, what exactly is the hotspot? part of the die? Thanks.
Changed pads ? The pads are too thick causing the heatsink not making proper contact with the gpu die
What card and brand and thickness thermal pads did you use ?
Doubt the core temps are fine if the hotspot is 105c
Hotspot delta to core for 3080fe ideally should be 10-14c
3080FE GP-Extreme pads 2mm and 1.5mm, using only 2mm caused the die not to make any contact at all. Core and ram temps barely hit 70c during stress test but hotspot is still hitting 95c even after reseating it all.
My hotspot (on water) delta has increased from about 15 to 22-25C after 4 months or so using MX4, picked up some syy157 and will give a try when I get a chance. I would triple check the mount - the paste looks like it had good contact when you take it apart?
