I will take photos and maybe even video document my Nov 2021 drop 3080FE teardown. Im going to buy the 1.5mm Gelid Ultimate for the backside and ignore the front side and leave the stock pads there.You only really need to do the side with the gpu for VRM and VRAM , replacing pads on backplate hardly makes any difference might as well keep the stock pads on
You could try 2mm gelid extreme if you get high GPU and hotspot change to 1.5mm gelid ultimate pretty sure you'll get the issue as the 3080fe I had issue with 2mm extreme pads was from the November drop, heatsink dated 06/18/2021
I tested few hours of mining on it , was 101mh fans at 60% and it never went above 82c on vram that's with 2 120mm fans underneath it at 1000rpm
Keep note everyone will get different results with different setups
Willl report back next weekend
