You need HWinfo64, it runs through rivatuner that is installed with MSI afterburner, just hit settings in HWINFO and in OSD RTSS pick what you want to show.
I went until they stopped 3 turns a time doing each corner. I pressed the pads well down as well before attaching cooler. You need a lot of paste if using MX4, thick X shape and big blobs in each area.
Oh you pre-compressed the pads. That's what helps 2mm Gelid Extremes work better (on cards that can use them).
That still doesn't explain the people who were getting 100C hotspot / Black Screen 100% fan speed with 2mm Extremes on 3080 FE's though (the 3090 FE absolutely ****CAN NOT**** use 2mm pads on the core side VRAM (VRM's are great for 2mm, only with Gelid Extremes though!)--the die doesn't even touch the bloody heatsink if you have Thermalright Odyssey, Arctic (6 w/mk) or Gelid Ultimates on it!)
I know NONE Of you are going to want to do this, but can someone who gets GOOD (<12C Hotspot delta) temps with 2mm Gelid Extremes and BAD temps with 1.5mm (uncompressed!) Extremes,
please post the ENTIRE date code shown on the back side of the heatsink (requires PCB removal)? Only 3080 FE or Ti FE users.
This is all the information I can find so far.
3080 FE heatsink (2mm Gelid Extremes=100C hotspot/overheat: 1.5mm Extremes+2mm VRM=perfect):
T01 M03
110-0313-000.A (last two letters after the A seem to be scratched out or missing unless it's just "A" and nothing else.
10-05-2020 (USA Format, October 5, 2020 manufacture date).
3080 Ti FE heatsink (2mm Gelid Extremes=black screen+100% fan/overheat, 1.5mm extremes=perfect)
T01 M03
110-0346-000.AHF
05-06-2021 (May 6, 2021)
These two heatsinks appear to be 100% identical besides date/lot #.
Note I saw a 3080 Ti FE user with a heatsink of december 2020 also. I can't find the picture.
Want to throw some petrol (remember I'm an American, we don't usually use that word, we just say "fuel") into the fire:
Here's a 3090 FE heatsink I saved:
T01 M03
110-0349.000.AHF
12-07-2020
Why are the 3080 FE/3080 Ti FE and 3090 FE codes so similar when the 3090 FE heatsink is much larger?
*Edit*
with some difficulty, I found a user who used 2mm pads successfully.
https://www.reddit.com/r/nvidia/comments/ojc10s/swapped_pads_to_3080_fe/
T01 M03
110-0313.000.A
09-04-2020 (september 4,2020)
Yeah this is bloody USELESS.
The two 3080 FE heatsinks are IDENTICAL
The one that got modded with 2mm extremes (no overheat). Stock pads:
https://i.imgur.com/bfBpLMv.jpeg
The fact that this is a straight down picture is completely unhelpful also.
The one that got modded with 1.5mm extremes (2mm=overheat). Stock pads:
https://i.imgur.com/nGnXkFT.jpg
(at least in this picture you can tell clearly that the stock VRM pads are thicker than the VRAM pads, which is why 1.5mm VRAM, 2mm VRM's worked nicely).
Besides the quality of the camera affecting how the pads look, I see no bloody difference!
Sorry guys but I give up here.
