No just that the VM guy on the live chat probably had no idea what you were even asking but just wanted to say yes lots of times.
I can offer some real-world experience here, as I've been in a similar situation to you, albeit with a smaller distance involved. Neighbours can get FTTC whereas my house can't get anything better than ADSL2+ thanks to BT's shenanigans. There's no chance of running a cable so I had to resort to wireless.ah right, yeh this is entirely possible!
So think its definitely possible to get the bandwidth I need, with low latency, but what I am worried about is packet loss. I play a lot of games so this is quite a big one.
There are a few things I can think of that might effect it. Signal interruption from nearby overhead power cables..? Bad weather? and just the way this devices work.
Do the other properties back onto yours?
If so get a fibre transceiver (in a small solar powered cabinet)and run your own fibre to the farmhouse.
Zero chance of that as the M5 is limited by its 100Mbit Ethernet port. You would probably need something like the Nanobeam ac to get actual uni-directional 150MBit throughput, those have GBit Ethernet ports and higher performance wireless than the Nanostations and if memory serves they go for around £90 each.Ok well this sounds promising. Like you, I have line of sight but the fresnel zone is a bit iffy. I'll be getting a 150/15 FTTH so it sounds like the Loco M5s might not be quite up to the task of carrying as close to 150 over 450m.
The cost of the cable would be >£800 and thats just the standard stuff. Armoured cable must be at least half again.
Ouch - just done a quick quote - £1687 for 500m Preterm armoured 4 core OM3.
What about OM2? Max length is 550m if running at 1Gb/s and a lot more if sticking to slower speeds.
some sort of 4g system sounds in order...
Assuming that 4G site is owned by one of the major phone networks then there is no chance you will ever be able to put anything on it and power it. Shooting it between the trees will be fine.
