yea if you're giving it away
LOL
I see that they've kept quite about this though.
unbelievable! How can AMD advertise a feature like Eyefinity without big warnings all over saying "u probably wont be able to use this feature". Ridiculous! Was the reason i wanted to upgrade I tried TH2GD previously but didnt like it enough to justify £250 on the box and then a gfx upgrade at £250 but the solution of just a gfx upgrade made it doable.
Boooooo, hiss to ATI unless they get the adaptors sorted real soon!
yes that right u cant use 3 monitors with dvi even with dongles i have tried.
tried using hdmi dongle display port dongles no go.
that sucks then. i wouldn't have minded buying an adapter.
no idea how i'd sort this out now. was planning a 3 screen setup in jan time. a re-think is needed i think
Bear in mind that with Apple and now the new ATi cards supporting DisplayPort, there's a good chance that DP will filter into mid-level monitors pretty quickly, just like HDMI is now on pretty much every 22" screen you can get, even the £150 ones.
Ok, so triple screen setups are going to be pricey as hell for the next, ooh, year or so, but I think come this time next year things will be very different and DP penetration should be much higher.
Still making it cheaper to buy a TH2G unless ur happy not having matching monitors
That's the special 5870 Eyefinity edition with 6 DisplayPort connectors. Available in November iirc.Sure I saw a picture of a multi monitor 5870 and it had lots of display port connections on the back, personally I have no interest in multi-monitors so sorry I did not pay much attention but I think I would have double checked requirements card and monitors first because a normal imfo is sketchy with new stuff !
It may have been fudzilla
So even if you put a DisplayPort adaptor on your monitor and connect to the displayPort on the ATI it isn't going to work?
Why not, for heavens sake?
Because though DisplayPort is capable of carrying a DVI signal (via separate pins), DisplayPort and DVI are not electrically compatible - their signals are different. The circuitry within the card uses some feature of DisplayPort that enables the Eyefinity feature (for some engineering reason beyond me). Hence, the card needs one *native* DisplayPort connection to a DisplayPort monitor.So even if you put a DisplayPort adaptor on your monitor and connect to the displayPort on the ATI it isn't going to work?
Yep me too. All the EyeFinity stuff I saw from AMD had footnotes saying DisplayPort was needed to use three monitors.I remember reading this ages ago, that you'd require to plug one monitor in via displayport.
