yes that right u cant use 3 monitors with dvi even with dongles i have tried.
tried using hdmi dongle display port dongles no go. ppl have messaged ati.
from ATI.... ?
http://www.pcper.com/article.php?aid=783&type=expert&pid=4For 3 DVI-derived ports, you will need an active DisplayPort-to-DVI adapter.
A couple of notes on these outputs - if you already have some DVI-ready monitors and are looking forward to triple monitor support you might be disappointed to learn that the DisplayPort connection requires an ACTIVE adaptor to be converted to a DVI connection. The adaptors are also expensive (around $100) and are pretty hard to find right now. AMD says they are trying to address this but short of selling their own version I am not sure what pull they have in this regard. Converting from dual-link DVI to DisplayPort, if you have more than one DisplayPort monitor, is a much easier task and only requires a less expensive passive adaptor.
Can anyone read the text on the adapter?
I'll try some googling.
That looks a little different but also looks like it does the job
Now to find the price!
ThanksJust can't find anywhere to buy it haha.
I should have read more about eyeinfity xD
EDIT: Epic find Typhoon!!!!!!!! Now to try and find out where I can get one of those bad boys!
Is this a definate fix then? Will it hook up old monitors and new, and work ok?
Oh you want that one sorry (same thing bar the sticker), http://www.bizlinktech.com/future_displayport.html
Or with a 1920x1200 limit
It says that this only supports 8 bit colour instead of 32 bit like the more expensive one.
