5900X
Save one for me please! I'll be putting my order in on the 5th for sure!
EDIT at £450 to £530 for the 8 and 12 core respectively I think I might just go straight for the 12 core 5900x.
Unless the latency becomes a signifcant factor, seems like a cheap additional 4 cores.
Added to wishlist for ease!
Ordered pretty much everything for a brand new build ready for grabbing a 5900X on the 5th. Indecisive on storage otpion still...Actually just waiting on OCUK to send the PSU, CableMod cables and Motherboard. Case, cooler, RAM and GPU are ready to go.
Thanks m8 for your help i was wondering and the internet didnt answer my question XD
Could you link me to a good one that you recommend
Make sure to buy a motherboard that allows flashing without a cpu. Or you may find you need a older cpu to flash it before you can use the 5000 series. Look for ones that have a Flashback feature or whatever the manufacturer calls it.
OR make sure the motherboard is already flashed for the 5000 series.
