650D my first WC build
What sort of temps do you have on 1x 240 rad and 2x 240 rad?
The loops was build with a taste, nice and tidy.
Not sure what you mean, I have 1x 240mm rad and 1x 200mm. I can't remember the temps when it was just the 1x 240mm but they wasn't to bad and then when I added the 200mm they only dropped around 3-5c off the load temp.
Nice build mate - I've just got a koolance 280mm rad cooling all my setup and it does a sterling job.
One liccle finishing touch needed - An AE5 unit! ;)
Thanks,
Some updates with photos:
Changes:
-3770K @ 4.8
-8GB Samsung Green @ 2133mhz
-Asus Sabertooth Z77 (Put the V Gene, 2500K and HyperX ram in girlfriends system)
-Swapped all tubing to Primochill Advanced
-Added 2x XSPC male/male connectors to straighten the return to res tube a little.
-Swapped pastel to UV blood red (loop went milky and didn't want to spend another £30 on filling it)
-Added another T section for draining in-between the two rads
Yep, you understood what I meant.
I wouldn't say only as the 3-5c add more headroom for higher OC :D
Nice bump, it was a good choice changing pastel to UV blood! Looks stunning :eek: !
Nice photography skills there mate. Setup looks nice, very impressive. Just finished my own 650D build so its interesting to see how other people set their cooling up. I've used some EK uni holders to mount my res on the opposite side attached to the optical drive bays. I've gone with the pastel blue coolant but think I may change to UV blue in a few month. Good work!
Thanks, Spooks.
I do like the tube res next to the 5.25 bays I was going to go with a very similar setup to yours, almost exactly the same as the 650D watercooling youtube video. I ended up going above the PSU as I like the look of the res I wanted to be able to see it right next to the side window, when it's on the desk.
I really like the blood red Ash! The sabertooth looks really good as well and imo gives your rig a gothic type feel. Really enjoyed your build log, It has given me some food for thought for my upcoming WC build ;)
Thanks, yeah I prefer the Sabertooth over the Matx V Gene in the 650D, looked a bit weird having 3/4 of a board in the case. If you need any help with anything Teejay give me a shout and I will try to help.
