Yeah will do thanks Ash. Pretty much decided on the parts, Not sure on the fittings at the moment, Might go with 1/2 barbs and 7/16 tubing with these
http://www.overclockers.co.uk/showproduct.php?prodid=WC-096-KA.
If I decide on compression's though, I was looking at either the XSPC ones or EK fittings. What size tubing and compression's would be best? My list thus far is.
1. XSPC Acrylic Reservoir For Laing DDC Pumps
2. Laing DDC-1T Plus pump (18W)
3. Fittings?
4. Alphacool NexXxoS XT45 240mm Rad
5. Primochill Primoflex Advanced Tubing x 2m (colour undecided)
6. 2x GT's @ 1850rpm
I already have A XSPC Raystorm waterblock for the 2500k and a EK 580gtx phantom waterblock. Hopefully should have everything in a couple of weeks.
I know what you mean regarding the V Gene, I always liked the idea of a smaller board, But it can seem lost in a 650d! Will def be posting up stuff when I start and no doubt need some guidance
thanks!
