700D carbon fibre build: Blackbox II
after being dormant for nearly three months, i'm up and running again:)
So nice to be off the laptop!
pleased with results, just need to install the rest of the white cathodes properly and put the 30cm UV one back in...
Look good fella :)
Personally I preferred the previous fluid colour with the LED lights you have in there. This one, although nice, just doesn't have that same nice glow. It is almost too dark
You still using the pulsing light setup? You didn't post a vid clip of that in action :p
ok so the res-->pump tube is slightly kinked though patent and at 60% pump speed does not seem to be impacting performance.
seems its too much for the LRT tubing.
any recommendations? if its 45 degree fittings how should I arrange it? so they are both angling toward each other to reduced turn radius?
I know what you mean re: old setup it did have a nice glow but it was time for a change, the new tubing looks really smart in person.
yeh the lights pulse very subtly I honestly don't know if the cam will pick it up but i'll try
sorted the kink with an EK rotary £3.50 on ocuk
was wary of rotaries but LOVE this one now! it's dead nice:
gutted with the UV properties of primochill LRT PRO, it just goes solid purple on the outside. Same with the EK UV fluid it doesn't glow at all!
will be on masterkleer next I think
Lights video:)
http://www.youtube.com/watch?v=75FDolDDG5c&feature=youtu.be
Thanks guys,
The 470s you see there are now in GPU heaven, the 680s aren't under water but have been considering it...
2020 The system looks like this!
Stayed with LED strips behind the Mobo, this time cablemods RGB wide beam.
Also have RGB on the EK waterblock but set it to white for this photo to match the CPU and Reservoir.
NB RGB E-loops
Phanteks cable extensions
uc
