Read back a few pages, Vega found a driver modification that allows you to push higher resolution and refresh rates over the single link DVI - I have done so and currently running full 120hz from the single link socket. iirc Vega is running his monitors at native res (1440p I think) @ 110hz.
Of course, I fully appreciate it is my own fault for assuming the Lightning would have dual-link (should have checked!). Is there any good reason for this btw? It's 2012 for goodness sake?!!
If you're looking to stick with one high res monitor like the hazro which only has the dl-dvi connection then go with another card like the ASUS hd7970 DC edition. Could even go for the 680 lightning assuming that card has a dl-dvi port. I've seen some pretty good benches with them
@hughy, keep an eye on the mm, have a feeling the adaptor you need may be for sale soon![]()
Fairly sure the 680 version does have dual link, waterblock in the works for that too.
Sweet man are you selling one?
I need one but ideally El Cheapo! £80 for an adapter? I hope it bloody comes all singing all dancing and with the ability to pimp my kettle for a steller cuppa?!
OK lads thank you for the information.
I am going to keep this 7970 I think and carry on waiting for these waterblocks to arrive in stock.
The deciding factor for me after much thought was actually the amount of RAM! My Skyrim is heavily modded and the cheapest 4GB GTX 680 is £499 on here. Thus, I would only be able to afford the 2GB edition. Not to mention the cost of waterblock etc for both.
Sad times regarding the single link DVI thought. Right kick in the balls tbh.
