good news for me! wouldn't mind that. even though no faster cards are out i get a choice![]()
Might not be so good news if they only give you a partial refund taking into account how long you've had it
Shame, pretty much every 7990 I know of (including mine) had to be RMAed as they fried themselves.
I used the refund money to get another 780 for tri-SLI. Very happy with it.
are you sure about that, because i'd say the 7990 is a flipping good card !
If you happen to get one that ran the way they did in the reviews, ie: 75-80c load which was very quiet. most of them though seemed to run into the 90's and over which kicked the fan up to really annoying levels. My own card gpu1 used to routinely hit over 103c. From what I've read online it just seems to be incredibly rare for a retail card to match what reviewers experienced.
yes it will run hot if you dont back off the volts to about 1.12, interestingly enough the FPS are the same as when you OC the card.....which makes no sense to me.
considering this, you're better off running it at 1.12v with all other settings at stock, the 7990 is nothing like the 7970, because that would OC quite easily.
Loved the look of the card but it was simply a night and day difference from what they claimed it was, hot, loud and annoying.are you sure about that, because i'd say the 7990 is a flipping good card !
yes, i bet it's the same as the 4770, badly applied thermal paste under the cooler, it might be worth redoing it soon
at 1.2v in Heaven the fans suddenly spin up and slow down, this keeps happening, it's very twitchy.... it makes one hell of a noise, this stops as soon as you undervolt it
Be careful if you do take it apart, one of the fan headers (the one at the fan furthest from the pci bracket) is literally under the edge of a heatpipe, makes taking It off very tricky. The wires in it are also very fragile, one wire went wonky on me and had to order a replacement fan from ebay. Redoing the TIM made no difference to temps anyway =/
Might not be so good news if they only give you a partial refund taking into account how long you've had it![]()
The new consoles have 8gb overall system ram with 6gb of that going to the GPU. That means ports will use pretty much the same.
really? why is this? my card is 10months old, so how much do they knock off?
so if they cant repair my card or replace it with something as powerful, they give you back some of your money, not all of it?
sorry but that seems wrong, i paid £470 for that card 10months ago and it failed, so i either want ALL my money back or my card repaired
