Ok i might have sorted my problem, maybe this can help you as well.
CPU at 4.5 with 1.3v in bios
Used all settings from 8Pack guide apart from didn't use XMP i have manually set to DDR4-3000 and left everything else for Ram to auto.
Also i noticed you are in slot 1 and maybe 3, i sure it says in the manual to use the grey slots 2/4 if running dual channel.(thats how i read it anyway)
You are at the same point as me, cpu fine at 4.5 (same volts and trying lower) but can not get PC to boot if i use XMP
mine arrived a few min ago, rad fins are all smashed up, called up ocuk there sending out a new one but cant guarantee it wont also arrive in the same condition![]()
As long as the air is being exhausted out of the top of the case, there isn't much difference (if any) between the fans being on the bottom of the radiator (known as push) or the fans on top (known as pull).
If you cant get it to post or boot with XMP try upping the voltage for RAM to 1.4v thats what I had to do.
Right almost finished. Waterpump I'm assuming going to the water pump connector on m/b? The two fans for the rad, can they be attached to the cpu_opt and cpu_fan connectors? Lastly I have a phanteks enthro pro I think, has a little hub for all the chassis fans with one main power that connects to the board, which connector am I best of using for that?
Well, got mine put together so i thought i'd share it.
Just need to overclock and move my SSD's over now
I'm assuming it's ok to connect the main hub power cable to any chassis fan header?
Thanks
