Looks good.
Those with memory issues try DRAM Voltage around 1.35 to 1,4 upto 1.45 is no issue 24-7
Also set IO voltage to 1.2 and SA to 1.2 report back.
Use the mem slot furthest from the CPU miss one slot then the next......
If need be you can also disable XMP and try 17-18-38 main timings at 3000mhz. I tested several of these kits without issue myself.
Will give it a try tomorrow and report back
Thanks
Tink
