hello, really need help here.. do get my 970s still and SLI, or go for 980 OcUK Ref, or the deal on MSI R9 290x 8GB, am only gaming @ 1080p. at min got R9 270.. if get only one card not SLI then goin get myself nice AK Racing Premium Gaming Chair Black & Black![]()
My opinion regarding 970SLI I had nothing but issues there is a voltage bug which drops the clocks on the cards
Really Tempted to send my G1 back as i feel a little "done" but do i ? is the 290x 8gb really got much more punch ? I have NEVER owned an ATI card, Always been a nvid fanboy but they really have got my back up with some of their comments around the net.
That's a bios issue rather than driver. I fixed that with my own custom bios.
GPU horsepower, the 970 should have it, but VRAM horsepower the 290X wins it.
1080P gaming, 970 all the way, its the champ.
1440P gaming, tough choice!
2160P gaming, 290X 8GB all the way. (But ideally you need 2-3 in CF)
I am the second owner of a MSI GTX 970 bought on 9/10/14. I got it on 3/11/14
Is it possible to send it back for refund or credit note or would I need to be the first owner? Thanks
I am the second owner of a MSI GTX 970 bought on 9/10/14 from OCUK. I got it on 3/11/14
Well I spoke to another etailer this morning which rhymes with van and they have agreed to take back my Gigabyte card.
Time to get another 8GB 290x ordered from OCUK
but what about SLI Gibbo in 1080p with the OcUK Ref cards yours and thanks
Just confirmed mine too, and from now i'm just gonna stick with ocuk.
Closing Thoughts
Compared to last week's article that looked at the GeForce GTX 970 in a single GPU configuration, the SLI results show more variance differences between NVIDIA's top two flagship products. In a vacuum, this wouldn't mean much - we expected there to be more complications and frame to frame variance when looking at multi-GPU configurations. That has always been the case regardless of how well tuned NVIDIA or AMD drivers get.
But under the light of the recent memory issues surrounding the GeForce GTX 970 we have to look at things a bit differently. Yes the GTX 970 has fewer shader cores and runs at slightly lower clocks than the GTX 970, but would we expect to see similar levels of frame rate consistency between it and the GTX 980 in these games, at these settings when running paired up in SLI? My initial inclination would be yes.
So the question sits before us: does the ROP count / L2 cache size difference that was revealed last week by NVIDIA account for the frame variance differences between the GTX 970 and the GTX 980 cards in SLI? More than likely: yes. And that may end the discussion for many of you but consider this last point. The largest difference in variance on BF4, the primary example of this showing up for me in data, was run at 3840x2160 and 150% pixel scaling. That is essentially running BF4 at 6K!
The Call of Duty Advanced Warfare results occurred at 2560x1440, a much more reasonable resolution. In that case the data didn't show a gap in experience between the GTX 970 SLI and GTX 980 SLI configurations, but my time playing it certainly did. The GTX 970 SLI setup result in more hitches and frame rate drops than the GTX 980 cards but again, we were pushing every setting to its absolute maximum, even going as far as enabling 2x supersampling.
My takeaway from today's testing is that users with or looking at an SLI setup of GeForce GTX 970 cards appear to be more likely to run into cases where the memory pools of 3.5GB and 0.5GB will matter. Because you are able to reach higher playable frame rates with two GTX 970s than just a single one, stretching out and increasing image quality settings is more common. If you are that type of gamer, looking to stretch the boundaries what settings are playable, then it is worth a warning about the differences between the GTX 970 and the GTX 980.
For the others out there, the GeForce GTX 970 remains in the same performance window it was at prior to this memory issue and specification revelation. For $329 it offers a tremendous level of performance, some amazing capabilities courtesy of the Maxwell GPU and runs incredibly efficient at the same time.
AMD is aware of this debate as well and it should surprise no one to see the Radeon R9 290X sitting at $299 after rebates from several add-in card partners. Let the GPU wars continue!
