Glad I am not the only one.....
I have a Ref 970 on Pre-order, now would I be better off cancelling that order and putting the money towards buying a Ref 980 or should I just stick with the 970.
Gaming is 24" @1080 with G-Sync Monitor, (being delivered today) if that helps any. But I want some future proofing as well.
Sorry if its off topic but I am that confused and really would like some peace of mind over it, as I don't have a lot of money to spare so I try to make the right purchase first time if I can.
I'm not so concerned about the 3.5gb of ram its more that some cards seem to **** the bed once they go beyond that
Think I was unlucky TBF!It was an awesome card for the time.
If the GPU has 3.5Vram and another memory pool of 500mb is it still Vram or is it using normal RAM? like DDR3?
Is this why people experiencing slow downs? Like if you run out of RAM your PC will start to use the Hard-drive Page file and also slow down the system..
I'm in exactly the same position. I also have an OcUK reference 970 on pre-order. I'm undecided whether I should stick with the 970, which I think would be fine for my current needs, or pay the extra for a 980 to get a more future-proof solution, given that future games will probably use more VRAM.
Think of it like this: the 980 has 16 SMMs (Streaming Multiprocessor Maxwell). all 16 need to be in use at the same time to achieve the quoted bandwidth figures. Now, the 970 has 13 of them, the other 3 being disabled. Because of this, bandwidth and therefor memory performance is affected. It seems that nVidia have attempted to optimise bandwidth by segregating the memory in to two chunks, 3.5gb and 0.5gb, the 3.5gb chuck having a 'higher priority' according to nVidia. It seems like the right approach to me but it would appear to be causing some people more problems than others once you start using that smaller chunk.
This issue is muddied by the benchmark in the op, which apparently wasnt very well written and is possibly exaggerating the results, so further clarification needed there. In addition to this, there is a question over whether the various reporting programs (afterburner etc.) are reporting the right memory usage. It's possible that these programs are not reporting usage of the 500mb chunk, meaning people could be using 4gb of ram but afterburner etc reports <3.5gb. I'm not sure about this because we've had AB reporting 4gb and over so we need clarification there also; This would also be a good time for comments from the authors of these programs, such as Unwinder who wrote rivatuner (which afterburner is based on).
So, too many questions unanswered at the moment. But what does seem apparent is that these problems arent consistent from one 970 to the next. This could be down to which SMMs the 970 has disabled - most if not all 970s will be produced from rejected 980 cores, so disabling different parts of the GPU may have different affects on memory access.
This non issue still fuelling the internet with nerd rage I see.
Id be mad too to learn that i could only use 3.5 out of my 4gb of RAM
I still classed as VRAM.
It slows down because the bandwidth from this 512Mb pool is much lower then the rest.
You have:
3.5Gb @ 224Gb/s bandwidth
0.5Gb @ 45Gb/s bandwidth
That's why performance tanks as the that smaller pool completely bandwidth starves the card.
I have pretty much decided to change the order to a 980.
Now I just need to decide which one to get Pallit,MSI or Zotac as I really need the reference cooler.
Except that's not the case is it...at least not on my system.
